Results 1 to 6 of 6
    Luismi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Guys i really need help with this =(
    This is my second time installing a custom ROM on my phone. I downloaded Cyanogen 2.0.3 (i think thats the latest one) and after i do the back up (Rom Manager), i get the Cyanogen animation and nothing happens after that. It stays like that. I tried doing the factory reset (after taking the battery out and turning the power on + volume down) but it doesnt let me. It says
    Parsing...[SD ZIP]
    [1] RADIO_V2
    Do you want to start update?
    If i click yes, it does it and then it goes back to the cyanogen animation. If i click no then the only option it gives me is to reboot and it goes back to the animation too!!! =(
    I think its because i might not have cleared and wipe the data before intalling....
    What should i do???? Please help!
    Thanks in advance
  2. Thread Author  Thread Author    #2
    Luismi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Talking
    I fixed it. I had to take the SD Card out then it let me get to the factory reset. I did it and now is working fine.
  3. #3
    mjneid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CyanogenMod N252
    Default
    Quote Originally Posted by Luismi View Post
    Glad you got it working. By to answer the question as to why. Youhad a file named PD15IMG on your SD card. Delete that file and you'll be good to go.
    Sent from my NookColor using Tapatalk
    Luismi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks for replying!
    I'm completely new to all this stuff so i don't know much about this. If Im not wrong, I think I read some where that I need that file just in case I want to unroot or go back to custom Rom or something like that...? Is that right? Do I need that file at all?
  5. #5
    Kevin OQuinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    9,911 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    You can always store it on your computer and put it back on the SD if you do need it. I'm not sure if you do or not, though.
    Luismi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I guess....
    Thanks for the info
