Results 1 to 4 of 4
    Default Basic function questions for my Nexux 10
    l'm fighting my way thru basic functions and am baffled by these:
    1.How to minimize a screen and how to do it and not lose the sound while clicking on a new
    screenscreen2. How to copy and paste 3. How to find Adobe Flash Player on Google's Play Store
  2. #2
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Default Re: Basic function questions for my Nexux 10
    Quote Originally Posted by thailen View Post
    If you're using an app that plays media (i.e. audio, video) and you want it to keep playing when another app is in the foreground or when going back to the homescreen, that's something that has to be built into the media-playing app itself -- the developer has to build it so that the media continues to play when the app is no longer in the foreground. The Play Music/Google Music app, for example, has this functionality. The YouTube app and Chrome browser do not (as they are not explicitly intended for this type of use).
    You can copy and paste text from text boxes in applications by long-pressing on the text. You should then see options such as select all, copy, cut, and paste. They will either be in a pop-up box near the text you selected, or present in the "Action Bar" near the top of the screen. Take a look at this image. There are two screenshots, the one on the left shows what's called the "Contextual Action Bar" with options relating to the text that has been selected in the application shown.
    As for Flash, I'll let someone else answer that. I don't keep up with Flash support, sorry.
  3. #3
    paintdrinkingpete's Avatar
    Posts
    Global Posts
    4,297 Global Posts
    Carrier
    TNTC
    You can't. Adobe discontinued support for Flash on mobile devices quite some time ago, and hasn't been available for Android since ICS. In other words, you can't install Flash from the Play Store. There may still be methods to side-load Flash to work with the Nexus 10 (I honestly haven't checked myself), but you'd have to search the forums for that.
  4. #4
    Some browsers have flash capabilities built-in such as Firefox.
  1. Calender Question for my Charge
    By mrcraigp in forum Verizon Droid Charge
    Last Post: 10-01-2011, 10:29 PM
  2. Got an update for my Tab 10.1
    By mrmanishs in forum Samsung Galaxy Tab 10-inch
    Last Post: 07-06-2011, 01:09 AM
  3. Video Recording and Playback question for my Evo..
    By Stroven Taulrok in forum HTC EVO 4G
    Last Post: 01-03-2011, 08:02 PM
  4. Another question for my buddy with Ally...
    By zrxoa1 in forum LG Ally
    Last Post: 11-30-2010, 09:53 PM
  5. question for people getting 10 plus hours
    By Rderosier86 in forum Sprint Epic 4G
    Last Post: 10-12-2010, 08:22 AM
