As the title says...
Can anyone explain the difference?
cheers
Alan
Ok, so as I understand it....
Unlocking the phone allows the privilidged commands to work. I assume it changes some permissions somewhere. But why does it wipe everything out?
Rooting the phone is what happens when you start actually using privved commands such as su.
Does that make sense?
Alan
in simpliest terms,
Rooting gives you superuser/adminstrative permission, you can make simply changes to the Operating system that you did not have permission to change before.
Unlocking your Bootloader allows you to put custom operating sytems on your device.
Thats great - thanks.
OK, so why does unlocking wipe everything? What is it ACTUALLY doing?
Alan
The instructions say the the device will be wiped - it's not something we have to do - it just happens.
Alan
From this forum http://forums.androidcentral.com/ne...e-lock-google-nexus-10-bootloader-mac-pc.html
6. After you have got the ID just type(without qoutes) "fastboot oem unlock" in your command window.
7. Look to your tablet, where you'll have to verify the process. Remember that there's no way to undo the data loss that will happen the instant you say "Yes".
It also makes me sad that Samsung fanbois are worse than Apple fanbois ever have been. None of the people making these phones love you. You are just a number to them, a filthy meat-sack that carries a wallet. Especially you Droidxcon.
#hate-them-all.
Unlocking the bootloader will wipe the device as a security measure. If you lost your screen-lock protected device and someone found it, all they would have to do is unlock the bootloader and they could extract all of your sensitive data from it... so the data wipe is there to protect you from that ever happening since it ensures that if someone tries to hack into your locked device they will have to wipe all your information off of it first.
So, do I have to unlock it to root it? There's a post on the xda sitewhich suggests you don't have to.
Alan
