Results 1 to 15 of 15
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    Default What is the difference between unlocked and rooted?
    As the title says...
    Can anyone explain the difference?
    cheers
    Alan
  2. #2
    Ry
    Ry is offline
    Ry's Avatar
    Posts
    Global Posts
    4,367 Global Posts
    Default Re: What is the difference between unlocked and rooted?
    Quote Originally Posted by alan sh View Post
    cheers
    Alan
    Rooting - The Android Dictionary | Android Central Rooting - is it for me? Some Q&A | Android Central
    a.k.a. RyZR from HoFo
    Motorola DROID Bionic (6.7.246.XT865.Verizon.en.US, Ice Cream Sandwich 4.0.4)
    Google Nexus 7 (JDQ39, Jelly Bean 4.2.2)
    What other devices have I had? Here's my phone timeline.
    Support your favorite Android app and game developers. Pay for apps! And don't block ads!
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    Ok, so as I understand it....
    Unlocking the phone allows the privilidged commands to work. I assume it changes some permissions somewhere. But why does it wipe everything out?
    Rooting the phone is what happens when you start actually using privved commands such as su.
    Does that make sense?
    Alan
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Alan
    in simpliest terms,
    Rooting gives you superuser/adminstrative permission, you can make simply changes to the Operating system that you did not have permission to change before.
    Unlocking your Bootloader allows you to put custom operating sytems on your device.
    If i've made life easier buy me a Macchiato
    Thanked by:
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    Quote Originally Posted by DroidXcon View Post
    in simpliest terms,
    Thats great - thanks.
    OK, so why does unlocking wipe everything? What is it ACTUALLY doing?
    Alan
  6. #6
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Alan
    I'm not sure why you have to wipe. Maybe the unlocking process changes permissions on all your data and is easier to just wipe and start over during this process. But if the directions say to wipe its best to follow them
    From my Galaxy Note 2 via Tapatalk
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    The instructions say the the device will be wiped - it's not something we have to do - it just happens.
    Alan
  8. #8
    msndrstood's Avatar
    Posts
    ROM
    Stock JB 4.2.1
    Good questions. :thumbup:
    What?! ...I'm msndrstood.
    via Gnex
    What?!...I'm msndrstood.
    Sent from my Gnex from 'Just Over The Line'.
  9. #9
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Alan
    It is wiped based on a command you put in during the unlocking process. I think fastboot -w (or something to that effect) unless we are looking at different methods
  10. Thread Author  Thread Author    #10
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    From this forum [How-to] Unlock/Re-lock the Google Nexus 10 Bootloader (Mac/PC)
    6. After you have got the ID just type(without qoutes) "fastboot oem unlock" in your command window.
    7. Look to your tablet, where you'll have to verify the process. Remember that there's no way to undo the data loss that will happen the instant you say "Yes".
  11. #11
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Ah ok well either way, you don't really have a choice in the matter. You know probably knows the answer Jerry. Lets quote him to get his attention.
    Quote Originally Posted by Jerry Hildenbrand View Post
    It also makes me sad that Samsung fanbois are worse than Apple fanbois ever have been. None of the people making these phones love you. You are just a number to them, a filthy meat-sack that carries a wallet. Especially you Droidxcon.
    #hate-them-all.
    Jerry why does wiping data need to be done during bootloader unlock
  12. #12
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Unlocking the bootloader will wipe the device as a security measure. If you lost your screen-lock protected device and someone found it, all they would have to do is unlock the bootloader and they could extract all of your sensitive data from it... so the data wipe is there to protect you from that ever happening since it ensures that if someone tries to hack into your locked device they will have to wipe all your information off of it first.
  13. #13
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Quote Originally Posted by 2defmouze View Post
    Thanks so much, that makes sense
  14. Thread Author  Thread Author    #14
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    So, do I have to unlock it to root it? There's a post on the xda sitewhich suggests you don't have to.
    Alan
  15. #15
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Alan
    You don't have to but you may aswell get it unlocked its nit much more effort
  1. What is the difference between Rooting and Unlocking Bootloader??
    By coheed01 in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 01-30-2013, 04:24 PM
  2. what is the difference between nandroid backup and backup
    By garcia_jx in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 03-13-2012, 11:43 PM
  3. What is the difference between a launcher and ROM
    By chrstdvd in forum Motorola Droid 2
    Last Post: 03-13-2011, 06:22 PM
  4. What is the difference between and app and a widget?
    By alexsdogpound in forum General Help and How To
    Last Post: 05-18-2010, 12:54 PM
  5. What is the difference between Cyanogenmod/Koush and Ultimate Droid?
    By kalldrexx in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 04-24-2010, 10:13 PM
