Nokia accessoires work with nexus 4 ?
Normally they should work because the 920 andthe nexus 4both have the same wireless charging standard and nfc right ?
[Only registered and activated users can see links. Click Here To Register...]
Sent from my ASUS Transformer Pad TF300TG using Android Central Forums
Re: Nokia accessoires work with nexus 4 ?
They do work with the N4.
Looking for "Qi wireless charger" will net you compatible chargers. I believe Eveready had 2 on Amazon, with multiple spots for all your Qi charging needs. ;)
I think on this board, maybe by Phil before he stated the Fatboy works. But theoretically they all should.
I have a Nokia wireless charger, it was included with the Lumia 920, and I can get it to charge the Nexus 4, but it's intermittent. No matter where I place the phone, it stops charging, charges, stops charging, then the plate will blink fast (which means there's a problem). The Lumia charges very easily no matter where it is.
I wouldn't recommend the Nokia pad for the Nexus 4 based on my tests. Anyone else try this?
These do not work.
How many times do we have to say this? If you did a quick search you would have found tons of posts about these charges from Nokia NOT working.
Do a search and see for yourself.
BTW, I own one so I'm speaking from first hand owner experience.
Save your money and get an LG WCP 700 or a Energizer one.
Sent from my Nexus 4
