Results 1 to 10 of 10
- 11-10-2012, 10:09 PM
Thread Author #1
- 11-11-2012, 09:02 AM #2
Re: Nexus 4 Accessories - External Battery
Subscribed, I'll need one of these as well. waiting for opinions. (Your Amzer link seems broken though.)
Google GN (4.2.2) N4 (4.2.2), iphone 5, Galaxy S2 (PureGNexus ROM ics),N7(4.2.2) AT&T - 11-15-2012, 11:38 PM #3
The higher the amps, the faster it will charge your battery. Tablets usually have higher amps because they have bigger batteries and you don't want to wait all day for it to charge.
2A should be fine for the Nexus 4. - 11-16-2012, 09:42 AM #4
No!!!!!!! You'll brick your N4 if you use a 2A charger, the charging circuit inside modern cellphones is designed to accept 900mA-1A at 5V. If you supply 2A, that's double the circuit can handle.
Google Nexus 4 - Straight Talk
HTC Evo V - Virgin Mobile (available for sale)
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 11-16-2012, 09:58 AM #5
- 11-16-2012, 10:12 AM #6Google Nexus 4 - Straight Talk
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 11-16-2012, 10:36 AM #7
I don't think the linked article supports your theory but it is a good read about the quality of knock-off chargers.
AC did a piece awhile back about using a 1.8A Blackberry charger.
Accessory Tip: BlackBerry Premium Charger rapid-charges Android phones, too | Android Central - 11-16-2012, 10:45 AM #8
As AC have pointed out, if the phone supports rapid charging, then you may be able to use a 2A charger. But remember, fast charging the battery also reduces its overall longevity. Its always better to stick with what the phone manufacturer advises, after all they have designed the phone and its charging circuit
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 11-16-2012, 11:19 AM #9
Your new advice is a lot different from "ZOMG NO!!!!!!!! YOU WILL BRICK YOUR DEVICE!!!"
Whether your phone supports rapid charging or not, you can use a 2A charger. Here is a direct quote from the article - "Not every phone will allow for rapid charging, but for the ones that do you'll be glad you have a charger that takes advantage of it (and no, you won't damage your phone even if it doesn't make use of the higher amperage)."
The possible longevity reduction isn't enough, IMO, to worry about.Last edited by HAAS599; 11-16-2012 at 11:43 AM.
- 11-17-2012, 08:56 PM #10
My house and office are littered with BlackBerry PlayBook chargers. I use them to charge everything with a micro usb. I have since the PlayBook first came out, I haven't encountered and ill effects. My phone's battery has been charged by a PlayBook charger every single day for the last year. It still holds a charge.
Meh, I'll keep using my PlayBook chargers.
- - - Updated - - -
Nexus 7 external battery charger
By Soundtrack to Chaos in forum Google Nexus 7 Tablet AccessoriesReplies: 1Last Post: 09-19-2012, 05:18 PM -
2200mAh Power Back Case External Battery for Samsung Galaxy Nexus
By zedorda in forum Verizon Galaxy Nexus AccessoriesReplies: 17Last Post: 06-15-2012, 11:43 PM -
External battery charger $12.98
By emaster101 in forum EVO AccessoriesReplies: 7Last Post: 06-07-2010, 01:54 PM -
HyperMac External Battery for EVO?
By Alchematron in forum HTC EVO 4GReplies: 6Last Post: 05-29-2010, 08:02 PM -
External Batteries for the Evo 4G
By Android Believer in forum EVO AccessoriesReplies: 2Last Post: 05-27-2010, 01:39 PM
Reply
