Where do you buy the energizer one?
Correction, does not work.
It'll say charging, but it will keep going on and off. Does not "hold" it charging.
I can confirm that the Nokia charger works with the N4 only when it's placed centered with the bottom of the N4 between 1/4 to 1/2 inch above the bottom of the charging plate. Just charged it to 100% last night. Cheers!
Now that you know the spot, can you get it to reliably charge on the first placement or do you have to fiddle with it for I couple seconds to get it on the base just right?
Anyway you can post a short video tutorial? A lot of people can't seem to get it to work.
This eBay seller has "more than 10" Energizer dual station units available for Buy-It-Now price $59.95 plus $8.05 Priority Mail shipping.
I just ordered one so that my N4 and my wife's can spend the night together on the pad while we spend the night together in bed. Sort of romantic, don't you think?
Energizer Battery IC2B US Qi Enabled 3 Position Inductive Charger Black | eBay
Sure. I would say that once you know the spot it's pretty reliable placement. It's kind of an inconvenience so I wouldn't recommend buying this charger if there are alternatives.
Thanks for the video. What's the live wallpaper you're using? I don't recall the old grass LWP either having clouds or being available on the stock Nexus.
I just got my LG WCP-700 wireless pad at Verizon and it works great! Beeps once when you first put it on and that's all... No other beeping or buzzing!
