Results 1 to 15 of 15
- 11-27-2012, 12:43 PM
Thread Author #1
Energizer Qi Wireless Charging Pad & Cases with it
I was just at Best Buy and an employee in the mobile phone area told me that the Energizer pad will NOT work with a case, TPU, etc on
1. Is that correct?
2. Is there one out there that will work with it on
3. If not, is anyone interested in buying this at a discounted rate. It was bought from Sears, hasn't even come in yet - 11-27-2012, 06:49 PM #2
Re: Energizer Qi Wireless Charging Pad & Cases with it
Hmm.. Maybe thats why Google offered a bumper, rather than a case, so that most of the phone is not obstructed, while still somewhat protected.
I hope more various manufacturers come out with bumper cases. I doubt google will ever have enough of a supply for our demand. - 11-27-2012, 09:51 PM #3
1. no
2. i've used the only case available (the s-line tpu case) with both the energizer pad and the lg pad. both work just fine. the case actually works BETTER with the energizer, because it makes it "stick" to the super slick surface.
3. you should really try it. but if you don't want to i'm sure you can get your money back on it. they're selling pretty well on ebay and amazon, strictly because of the nexus 4. - 11-29-2012, 12:22 PM #4
- 11-30-2012, 05:20 PM #5
- 12-01-2012, 11:49 AM #6
I have the energizer charger but didn't even notice there was plastic film on it. My Nexus was always slipping off of the charger but once I took off the film its great. The surface is a little bit sticky/tacky and works great. For anyone that doesn't realize it, there is plastic film and the film is way slicker than if you take the film off.
- 12-01-2012, 12:02 PM #7
Does wireless charging act like wifi signals in respect to distance from the coils causing reduced charging capabilities or does it either work/not work?
- 12-01-2012, 05:03 PM #8
- 12-01-2012, 06:12 PM #9
- 12-01-2012, 06:15 PM #10
Correct. These chargers are flying off the shelves. No one can seem to keep them in stock and I'm taking about all Qi chargers, not just the Energizer.
Anyway, I've been doing a lot of testing. Seems the Energizer is a bit particular about where you place your phone on the mat. Too high and it won't charge. To low and it won't charge. To far left or right and it won't charge. It's like the Goldilocks of Qi chargers, lol.
As for cases, I've been testing with things of varying thickness. You can definitely use a case with this charger but you have to place it right or it won't charge. Even a pretty thick case will work as long as it's seated in the right spot on the charger.
Yes, charge IS affected by distance so the thicker the case, the slower it will charge but it will still charge.
But honestly, your main concern when trying to use this charger with a case shouldn't be "how long will it take to charge?" but " how hot will the Nexus get inside the case while it's charging?"... And the answer is: PRETTY DAMN HOT!
I would strongly suggest that you don't make a habit out of charging your Nexus for long periods of time inside anything other than the official bumper that has everything exposed except the very sides. Anything that covers more of the phone will cause heat retention that can cause the Nexus to overheat... So you've been warned.
Use your brain. Don't be lazy. Take your $400 investment out of a thick or enclosed case for longer charging. Or don't come here b*tching about how it melted or how it caught on fire or how it doesn't turn on anymore due to overheating. :rolleyes:
Sent from my Nexus 4 - 12-01-2012, 06:52 PM
Thread Author #11
- 12-04-2012, 12:17 AM #12
There's an LG wireless pad on Amazon I want to try out. I've got the bumpers on the phone. I've read somewhere that it will charge with a thinner case on the phone, but it might slow down the charging rate. Haven't tried it yet.
- 12-04-2012, 10:29 AM
Thread Author #13
- 12-04-2012, 07:26 PM #14
- 12-04-2012, 07:32 PM
Thread Author #15
Wireless Charging Pad for nexus 4 leaks out
By still1 in forum Nexus 4 AccessoriesReplies: 23Last Post: 11-13-2012, 08:48 AM -
By still1 in forum Google Nexus 4Replies: 13Last Post: 10-30-2012, 07:25 PM -
LG Wireless Charging Pad doesn't charge my TB!
By juker1103 in forum Thunderbolt AccessoriesReplies: 0Last Post: 08-07-2011, 05:19 PM -
By juker1103 in forum Verizon HTC ThunderboltReplies: 0Last Post: 08-07-2011, 05:19 PM
Reply
