Results 1 to 25 of 26
- 12-03-2012, 01:40 PM
Thread Author #1
Best Car Charger?
Which one do you use?
Can the Nexus 4 take advantage of rapid chargers? Will providing more than 1A make a difference? I know I at least need one that provides the proper signal to the phone to charge on AC vs USB. - 12-03-2012, 03:13 PM #2
Re: Best Car Charger?
This one has pretty good ratings and is OEM: Amazon.com: Motorola Vehicle Power Adapter micro-USB Rapid Rate Charger: Cell Phones & Accessories
Its 950mA, so little less than the bundled LG wall charger, but it will work just fine. A good quality branded charger is really important if you want to protect your investment.Google Nexus 4 - Straight Talk
HTC Evo V - Virgin Mobile (available for sale)
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 12-03-2012, 03:18 PM #3
- 12-03-2012, 03:34 PM
Thread Author #4
Thanks guys! Ordered one.
- 12-03-2012, 03:38 PM #5
i bought 2 of them, and both micrco usb plug became loose after using them for a couple months. it would fall out with the phone. I personally use this one. plug 2 is 1 amp and charge my phone as fast as my home charger.
Amazon.com: PowerGen Dual USB 3.1A 15w High Output Car Charger for Apple iPad 2, New iPad 3 4, iPhone 5 4s 4 3 3Gs, HTC Samsung Motorola Android Phones (USB Cable NOT included) - white: Kindle Store - 12-03-2012, 03:43 PM #6Google Nexus 4 - Straight Talk
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 12-03-2012, 03:45 PM
Thread Author #7
- 12-03-2012, 04:00 PM #8
- 12-03-2012, 05:48 PM #9
- 12-03-2012, 06:06 PM
Thread Author #10
I just noticed I put this in the wrong forum. Can any mods please move it to the accessories sub forum? Thanks!
- 12-04-2012, 12:13 AM #11
+1 on that Moto charger. The size and the blue LED that comes on when it's plugged in are garish, but you get used to it. Make sure it's the OEM one that charges at 950 mah.
- 12-16-2012, 08:55 PM #12
I ordered the Motorola charger from amazon and used it twice with my N4, both times it charged the phone to 100%, but for some weird reason the phone discharged at almost double the rate (battery went down to 5% in less than 20hrs, normally it takes about 30hrs based on my usage). When charged with the supplied LG charger, the phone retains the charge MUCH longer. Has anyone seen this behavior before?
The only difference I can think of is that the Moto charger is 950mA and the LG charger is 1200mA.Google Nexus 4 - Straight Talk
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 12-17-2012, 03:52 AM #13
- 12-17-2012, 08:51 AM #14
- 01-10-2013, 09:47 PM #15
OEM usb cable with a 2.1 amp charger.
- 01-12-2013, 11:39 PM #16
- 01-13-2013, 09:48 AM #17Google Nexus 4 - Straight Talk
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 01-13-2013, 10:36 AM #18
- 01-13-2013, 03:58 PM #19
- 01-13-2013, 08:29 PM #20
The Motorola charger works fine for me on my Nexus. Not sure what the issue is on yours TundaBow.
- 01-14-2013, 03:26 PM #21
Here is a picture of the stock N4 charger(left) and the Motorolla charger above(right). The only difference I see is the "slots" inside the plug. All I can tell you is the Moto charger is A LOT harder to put in and remove. You all's experience may be great, but to those looking to buy this charger, just know MINE is not right.
- 01-15-2013, 03:41 AM #22
rapid charger is a danger for cell phone, you should never use it to charge your cellphone.
- 01-15-2013, 10:36 AM #23Google Nexus 4 - Straight Talk
Previously - Motorola Atrix 4G | Samsung Captivate | Motorola Droid 2 | Samsung Epic 4G - 01-16-2013, 08:51 AM #24
Looks like in the review and in the pics, there are some that go out that are fakes! And some are real I guess? Weird. I'll have to check mine out.
Customer Image Gallery for Motorola Vehicle Power Adapter micro-USB Rapid Rate Charger - 01-16-2013, 02:17 PM #25
What tech specs 4 car charger? & what one do you like best?
By Pdelponte in forum Samsung Galaxy S3 AccessoriesReplies: 2Last Post: 07-27-2012, 02:35 PM -
By Pdelponte in forum Samsung Galaxy S3Replies: 2Last Post: 07-27-2012, 02:35 PM -
Best car charger for Nexus?
By KoukiFC3S in forum Verizon Galaxy Nexus AccessoriesReplies: 89Last Post: 03-19-2012, 03:24 PM -
HTC branded car charger for E3D listed at Best Buy
By roark1138 in forum HTC EVO 3D AccessoriesReplies: 3Last Post: 06-22-2011, 03:54 PM -
Best Buy Car Charger
By jasonaward in forum Samsung Galaxy TabReplies: 6Last Post: 11-15-2010, 11:36 AM
Reply
