Results 1 to 9 of 9
- 01-31-2013, 02:15 AM
Thread Author #1
Do the Galaxy Nexus docks fit the Nexus 4?
I have a Galaxy Nexus with the car dock, the home dock, and the office dock (HDMI). I've made a big investment having all those docks and I really want to upgrade to the Nexus 4 but I'm wondering if my docks will continue to work, the shape/size is really similar and I've seen that the Nexus 4 fits in the GNex's car dock, it sticks out a little, but it fits.
The wireless charging orb seems promising, and I wouldn't mind buying docks for my home/office/car, but there are none. Samsung did a really good job of accessorizing the Galaxy Nexus, but so far I haven't seen anything from LG aside from the bumper and the Orb, which is not available anywhere.
Can anyone help me out?
Thanks! - 01-31-2013, 09:09 AM #2
Re: Do the Galaxy Nexus docks fit the Nexus 4?
without actually testing any of this first hand, I can say with a good amount of confidence that it won't work. the N4 and GNex are very similar sizes, but they are shaped differently. The N4 is just a tad wider and isn't curved like the GNex so any dock made specifically for the GNex might not fit the N4.
However, that doesn't take into account the most important thing. The N4 does not have pogo pins. So while you might get the device to physically fit, the docks will be useless because they wont' actually do anything. The GNex connects the pogo pins in the dock to charge, output over HDMI, etc, and that simply isn't possible on the N4 since it doesn't have the pins. - 01-31-2013, 07:05 PM
Thread Author #3
- 01-31-2013, 08:07 PM #4
Just as an FYI. I have a Galaxy nexus and accompanying Car dock. I had the same quandary as the original poster. Having just bitten the bullet and purchased a Nexus 4 and tried the car dock last night, i can confirm it fits surprisingly well. The malleability of the substance which is closest to the phone body when docked allows for the phone to snap into place despite the slight differences in design
The obvious issue is charging though. As the other guy above rightly says, Nexus 4 doesn't have pogo pins and the design of this dock means the usb charging point is totally enveloped. So i'm contemplating a DIY session where i may cut out a micro USB charger sized section from the bottom of the charger and use that....at least until an official car dock comes along.
Hope this helps the decision.
Cheers - 01-31-2013, 11:44 PM #5
yea that's why I rarely buy "official" accessories anymore. I change phones every 18 months at most, so i go for car mounts, docks, etc that work with any device I want.
- 02-01-2013, 12:01 PM #6
Me too. I never buy device specific accessories. If you change phones ever 12 to 18 months, the savings in not buying all the extras will fund a new phone.
Semper Fi
I love my LG Nexus 4! - 02-02-2013, 06:59 AM #7
- 02-04-2013, 10:00 PM
Thread Author #8
Thanks you guys! I already ordered my Nexus 4 so I'll find out soon enough, I always try to buy device specific accessories because most of the time they fit/look better than any 3rd party solution out there, I've gone trough a lot of car docks and they've never worked right until the Galaxy Nexus one, they always fall off, are wobbly, phones slip out, can't get them into that perfect position, etc...
Good news is that there are a bunch of inductive charging mats/docks, I'll look into those... - 04-23-2013, 05:33 AM #9
Have you tried the Nexus 4 in the Galaxy Nexus docks yet?
Edit:
I can answer this myself, it does not fit.
My Galaxy Nexus desktop stand is too narrow for the Nexus 4 and the car dock has a 3,5mm plug beside the usb port and the Nexus 4 has the hole on the top side of the phone so it does not fit there either.
Anyone know if the G.Nex (Samsung on Verizon) dock fits the SG3 ?
By jecilop in forum Samsung Galaxy S3Replies: 1Last Post: 11-20-2012, 05:33 PM -
Why I Prefer the Galaxy S II Over the Galaxy Nexus
By milominderbinder in forum Sprint Galaxy S II Epic 4G TouchReplies: 24Last Post: 12-21-2011, 06:14 PM -
Is the Atrix Lap-dock worth the cost, what does it really add to productivity/experi?
By Dude2 in forum Atrix AccessoriesReplies: 21Last Post: 11-30-2011, 11:10 AM -
25 Reasons Why The Galaxy S II Is The Best Phone on T-Mobile
By milominderbinder in forum T-Mobile Galaxy S IIReplies: 22Last Post: 10-18-2011, 01:29 PM -
By Dude2 in forum AT&T ATRIXReplies: 5Last Post: 02-23-2011, 12:18 AM
Reply
