Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Like Tree4Likes
  1. #26
    Default Re: Nexus 4 Wireless Charging Orb Delivered
    I'm not really sure. If it is a form of suction, it's not suction like I'm used to (i.e. suction cups). You don't have to press or secure it. It just kind of sticks.
    Here's two more photos of the face of the charger:
    The material is a bit raised in a few areas (just looks like manufacturing flaws). Two spots pointed out here:
    One random note: the face of the orb smells like paint.
    Thanked by:
    omgzam
    minnemike likes this.
  2. #27
    It's like some sort of alien device. I can't figure it out.
    So far I've tested it with the Nillikin, Poetic bumper and atmosphere, and a dual layer otterbox knock off type case - works with them all!
  3. #28
    Quote Originally Posted by omgzam View Post
    So the phone is held in place through suction?
    No, the rubber on the front of the Wireless Charger is very tacky/sticky, combine that with the glass back of the Nexus 4, and it has a strong hold on the phone. But it is not held in place by suction. I would not recommend holding your charger upside down while the phone is attached, like in the image above. You might not have the same results.
  4. #29
    My poetic bumper case does not work well with charging orb. Kind of just slides off. The glass back cant make contact with the orb, bumper doing its job! Disappointing, but oh well.
    Sent from my nexus 4
  5. #30
    Quote Originally Posted by nizael View Post
    Well that fixed that....thanks...I assumed that this would be the only dock for this phone . Hmmm i wonder if there is another one in the works...
    You have to remember that the Galaxy Nexus also runs 4.2... and has a pogo pin dock. Those are just generic options. No dock is in the works for the 4 that anyone seems to know about.
  6. #31
    Quote Originally Posted by legec117 View Post
    mine works with it but it does take careful placement. try pressing it down on to it a tad. i do have a back side screen protector on mine which might make it more sticky.
  7. Thread Author  Thread Author    #32
    There deff is some magnetism going on. When i hold the phone close by i can actually feel the orb kind of pull the phone towards it. Not a strong pull but a pull non the less.
  8. #33
    Uh-oh. I woke up this morning to a 100% charge from the wireless charger and have been using the phone since. But when I just returned the phone to the charger, it's giving me the dreaded cycling where it bounces constantly between charging and not charging. I've read about this in with other Qi chargers. I tried putting it in different spots on the charger and resetting the phone, but no luck. The battery percentage is going down during this process. Thoughts?
    UPDATE: Resolved. Low power USB power adapter was the cause.
  9. #34
    Quote Originally Posted by Paulbronte1 View Post
    I'm 99.9% sure there is no magnet and I'm glad there isn't. A magnet would interfere with the compass in the N4, even after you remove it. You would be constantly calibrating the compass after charging.
  10. #35
    Quote Originally Posted by sholmes1019 View Post
    Figured out (sort of) my issue with charging/not charging. It was plugged into a Griffin dual USB travel charger, one of the older ones that is fine for phones but doesn't provide enough current for tablets. Switching it to the USB adapter from my iPhone 4 fixed the problem and it wirelessly charges fine now.
    That said, there are two things that are surprising about this:
    1) the Nexus 4 charged perfectly fine using that Griffin charger for 10 days. So, it looks like the orb requires more current than the phone.
    2) this doesn't explain why the phone charged overnight to 100%. As I said in my first post, when I woke up this morning I had a fully charged Nexus 4. It was only after that when it stopped charging.
    No big deal either way with these. They're non-issues going forward.
  11. #36
    rrspikes's Avatar
    Posts
    Global Posts
    127 Global Posts
    Quote Originally Posted by imnidiot2 View Post
    If there wasn't a magnet in the charging orb, a normal magnet wouldn't stick to the inside of the rubbery ring. You can feel a magnet being attracted to the orb from a good half inch away.
    Another test I did was to take my T-mobile S3 with the Verizon branded inductive changing battery cover installed on it. I put it on the charging orb with a piece of wax paper between them to rule out that it was the rubbery ring holding my phone. My S3 stays firmly in place.
    There is without a doubt, a magnet/magnets inside the charging orb.
    Sent from my SGH-T999 using Tapatalk 2
  12. #37
    My orb was delivered on Friday but since it was shipped to work I only got to set it up today.
    So far I have to say it's pretty cool.
    Seems to charge fine.
    Seems to stay on the orb quite fine.
    The angle is pretty great - with my left hand I can stop typing on my normal PC keyboard and extend my hand a little and tap out (or swipe out) a message in the N4 world.
  13. #38
    Quote Originally Posted by xstinkyx View Post
    Yeah - the grip is perfect to do pretty much everything on the phone without knocking it over - compared to most Qi chargers.
  14. #39
    Quote Originally Posted by rrspikes View Post
    The magnet is attracted to the metal that is inside the rubber ring. Install a Compass app onto the phone and bring the phone next to the charger while the compass is running. There is no effect. Remove the phone from the charger and bring a magnet next to the phone and the compass will respond.
  15. #40
    Its amazing to see how the technology is changing from the wire to the wireless chargers similar to what happened with the telephones to mobiles
  16. #41
    I got my Orb last Wednesday (7 days ago). I was aware from the literature and from other postings that dust accumulation could be a problem and cause the phone to slip. Up until last night, I had no problem charging the phone (naked) in landscape position. When not using the charger, I would lay the original plastic protector back on that came with the orb. I thought that would help reduce the lint/dust accumulation, but apparently not. About 4am this morning, my phone woke me with the low battery warning and I realized it had slipped off. It took me several minutes to get it back to charging on the orb and it jumped back and forth from "charging" to "low battery." I had to turn off the alarm display to finally get it to charging only.
    I thought I was being careful about dust, but it looks like the orb already needs a cleaning. I was too tired to investigate further this morning. I've read that having a screen protector on the phone's back is better than bare glass - for "sticking" purposes. I've also read to clean the orb using a plain water, or clear tape, and various other methods. What has worked for you?
  17. #42
    My Nexus 4 charging Orb doesn't hold my phone in place at all. I have the Nexus 4 and it just slides right off the charger forced by gravity. I do not have any case on the phone and both are brand new as of yesterday. Anyone else have this problem? My orb is just tacky and you cannot really feel any sort of magnetic attraction, maybe just a slight feeling. Thoughts?
  18. #43
    Quote Originally Posted by BeverageNinja View Post
    I found yesterday that a N4 with the back shipping film still on would stay on the orb even while gently shaking. (Coworker wanted to see if it would work in a vehicle.) You're right, I think, no suction, but I can feel a magnetic pull even with the orb not plugged in (no power to the inductive circuits).
    (Edit) Nope, nope, nope. Trying again tonight i find darned little evidence of a magnetic pull. That surface is super sticky....
    I can't imagine why. The bumper is only around the edge, right? The center of the orb is raised a bit and should still contact the back. Unless the bumper is really, really thick.
    Likewise. And sometimes (with it plugged in) I feel a vibration when the phone sets onto the orb.
    Read the fine print on your orb's adapter. It outputs 1800mA. Now read the manual. Now read the fine print on those other chargers. I wouldnt' expect a 5W 1A charger to fully supply the orb. I would not be surprised if the orb stopped working at some point from using a non-approved (< 1800mA adapter) while trying to charge the phone.
    Quote Originally Posted by PaulJManger View Post
    Weird. I haven't had that problem at all with a brand new N4 and brand new orb.
    Cleaning: Guys, trying using a inside out wrap of 3M Scotch tape to remove lint. I tried some lens cleaner liquid and a microfiber cloth, probably not the best thing for that surface. But tape should take the lint off. Or a lint remover roll like pet owners use?
    FWIW, my phone stays on the orb with a Poetic Palette back shell. The phone lifts off easier, in fact, than "nude" with the glass back.
    Sent by accident, not using the Android Central app
    Nexus 4 (Mako), Amaze 4G on T-Mobile. Nexus 7 16GB. Google Chromebook (2012 Samsung 16gb). Next stop, a Google flush toilet.
    Did I solve your problem? Hit the Thanks button. Was I just a nuisance? Sorry, can't bat .400 every day.
  19. #44
    Quote Originally Posted by ChromeJob View Post
    ... Cleaning: Guys, trying using a inside out wrap of 3M Scotch tape to remove lint. I tried some lens cleaner liquid and a microfiber cloth, probably not the best thing for that surface. But tape should take the lint off. Or a lint remover roll like pet owners use?
    Better: a sheet of sticky paper from a pet hair remover roller. Works fab.
    To finish off ... fresh can of compress air/computer cleaner.
  1. Wireless Charging Orb Price $60
    By Reptile1990 in forum Nexus 4 Accessories
    Last Post: 01-31-2013, 11:56 PM
  2. Nexus 4 Charging Orb - will it ever arrive?
    By TallPaul86 in forum Nexus 4 Accessories
    Last Post: 01-16-2013, 09:30 AM
  3. Wireless Charging Orb/3rd Party Qi Charger - UK
    By 1iam5mith in forum Nexus 4 Accessories
    Last Post: 12-05-2012, 10:46 AM
  4. Wireless Charging Pad for nexus 4 leaks out
    By still1 in forum Nexus 4 Accessories
    Last Post: 11-13-2012, 08:48 AM
  5. Wireless Charging Pad for nexus 4 leaks out
    By still1 in forum Google Nexus 4
    Last Post: 10-30-2012, 07:25 PM
