Page 1 of 3 123 LastLast
Results 1 to 25 of 54
Like Tree6Likes
    keld's Avatar
    Posts
    ROM
    4.xx
    Default N4 Wireless charger disaster
    Hi all,
    I was pretty excited to get my wireless orb, two nights I have it now, well something is really wrong with it.
    • Both mornings my phone was on the floor, there's no cover or protection on my phone, but after 20 minutes it starts sliding down then ends up falling
    • I got woken up at night because the screen went on by itself, I looked at the battery icon, the phone was well in place on the orb but the small lightning icon was on and off, like I was plugin and un-plugin the cable
    • The phone started opening apps, I was staring at it for a while, all of the sudden, the clock screen opens up then the Facebook app opens up too by itself!
    • Extremely slow charging, if you use the phone at the same as it's charging, it actually drains more battery but what it's actually charging
    I don't know what to think of it, maybe my orb has a problem bht if I get a new one, the sliding thing won't get fixed, I really do'nt get it, didn't they test it before, don't they know that their phone is like a soap bar?
    Is anyone having the same issues?
  2. #2
    Default Re: N4 Wireless charger disaster
    I dont get why your phone is "sliding off". My Nexus 4 doesnt move one bit. In fact when I grab it off the orb I have to give it a bit of a shake to detach.
    pontiac005 likes this.
  3. #3
    qnet's Avatar
    Posts
    Global Posts
    1,447 Global Posts
    ROM
    All stock right now
    I haven't had that issue but have read of a few others who have. It must be defective units.
  4. #4
    I haven't had the falling off issue, or any random application activity. It seems to charge pretty quick to me, about an hour or so longer than plugged directly in. I do have to almost shake my phone loose to get it off the charger and i can even pick up the charger with my phone, so it's hard to imagine how yours is falling off.
    My screen does turn off after some amount of time. I have it setup to go into the clock daydream when it's charging or docked but my screen will just turn off after a while; not sure whats going on with that.
  5. #5
    1. Make sure the orbs adhesive face is clean and clear of dust and dirt.
    2. Restart your Nexus 4.
    3. Check your settings making sure that things that drain a ton of battery are off like Miracast and Hotspot.
    4. Wipe down the back of your phone with a clean cloth to make sure there is no oily buildup, gak and/or dust/dirt.
    IMPORTANT: USE ONLY THE INCLUDED USB CORD & AC ADAPTER!! Use of anything else may cause damage to your phone, the charger or may not properly charge!
    5. Place your Nexus 4 firmly on the Orb. Make sure you are placing the phone so that the bottom is NOT touching the table but hovering about a 1/3 of an inch above it.
    (See user guide, tons of photos and videos online for placement reference.)
    You shouldn't have a problem if you follow the outlined steps. If you do continue to experience slippage or charging problems, contact Google. You might have a lemon.
    Good luck.
    Sent from my Nexus 4
    Thanked by:
    qnet
    keld's Avatar
    Posts
    ROM
    4.xx
    I cleaned the back of my phone, cleaned the orb (it was clean already), put the phone perfectly on it, set up a video camera and it took about 16 minutes to slide off of the orb... I guess I'll be returning it or maybe my phone is too heavy hehe
  7. #7
    Wow still it slides?
    Mine never moves. I leave it for 8+ hours overnight and it doesn't budge.
    If you cleaned it like you said and are placing it properly on the Orb yet still have slippage, definitely RMA it.
    Sent from my Nexus 7
  8. #8
    qnet's Avatar
    Posts
    Global Posts
    1,447 Global Posts
    ROM
    All stock right now
    Mine is starting to slide off now also. I'll follow the steps listed above to see if that helps. I hope this doesn't become a issue.
  9. #9
    qnet's Avatar
    Posts
    Global Posts
    1,447 Global Posts
    ROM
    All stock right now
    Quote Originally Posted by qnet View Post
    Cleaning the phone and charger did the trick for me, it works fine now.
  10. #10
    Quote Originally Posted by keld View Post
    Funniest thing I've seen all day. On a serious note, that orb definitely sounds like it needs to go back.
    Sent from my Sony Xperia ion
  11. #11
    bearda's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mine definitely slides. It was delivered todIay and I haven't been able to get it to stay on for more than 10 minutes. I tried removing the bumper and cleaning both the phone and the charger with no luck. I don't feel any real attraction between the charger and the phone, just the resistance from the rubber ring. Do you guys feel the phone snap into place on the Orb? I know my Zens Qi mat does.
    Already contacted Google support and they're going to try replacing the Orb. We'll see if the replacement does any better.
  12. Thread Author  Thread Author    #12
    keld's Avatar
    Posts
    ROM
    4.xx
    Actually min was able to stay on all night now, instead of just posing the phone on the orb I actually have to press it on it kind of like the orb was a suction cup and it stayed!
    We'll see if it stays again tonight or it was just luck because the rubber ring is still new. I don't know I have the feeling that this thing in a year or so wont work anymore...
  13. #13
    Thumbs down Re: N4 Wireless charger disaster
    I know this may sound obvious, but does everyone realize there's a very tightly-clad clear static-cling sheet that needs to be peeled off both the front and back of the Nexus 4, as well as on the mating surface of the charging orb? I had my N4 for days before I realized there was a plastic sheet that I hadn't peeled off the back of the phone. If you can see an IMEI printed on the back of your N4, then you haven't removed the static-cling sheet. (The IMEI is printed on the clear sheet, not on the back cover of the N4). If the rear clear sheet is still there, then that might account for some of the slipperiness between the N4 and the orb. Just a thought. Cheers!
    Update: My N4 began slipping off my orb a week after I started using it. When I read here and in other forums how many others were having this same issue, I called Google and they're sending a replacement since I've had my orb less than 15 days. If the replacement has the same problem, then I'll try to return the second orb for a refund, and watch for something else more appropriate to come along. Frustrating.
  14. #14
    bearda's Avatar
    Posts
    Global Posts
    93 Global Posts
    Quote Originally Posted by GeezingInVA View Post
    Clear sheet was off. Glass is pretty slippery stuff in it's own right.
  15. #15
    Wink Re: N4 Wireless charger disaster
    Oops! Okay. Thought it might be worth a shot. Cheers!
  16. #16
    What's the best way to clean the orb?
  17. #17
    Ood spit.
  18. Thread Author  Thread Author    #18
    keld's Avatar
    Posts
    ROM
    4.xx
    Well good news, it's been 3 days, and the phone never slid off the orb since I press the phone onto the orb before going to bed. Hopefully it stays that way.
    So I considered this case SOLVED... for now...
    @SOLGarion funny pic lol
  19. #19
    Glad that worked for you. I'm combing the forums and found this post and some videos of the issues.
    Just got my N4 yesterday with orb, its sliding like a toddler at an ice rink. I got a fugly case fromT-mo when I went to get my micro sim and orb holds that tacky thing like a champ and charges pretty quickly, too. I'm going to try pressing the bare phone--yes, plastic backing is off -- my house is dusty, so I've cleaned the rings multiple times during the night each time I found the phone "slumped" down onto the table. Connection (lighting bolt) goes on and off but no weird app happenings. Haven't tried Daydreams yet. still trying to get the thing fully charged, which it's almost done in the hour I've been truly awake (with ugly case on back only). Unbelieveable there is no routine charge indicator light. Google!!!! Always just a teaser away from perfection!
  20. #20
    My phone literally STICKS to the Orb, somehow. It's darned grippy. When I remove it there's a small suction release sound.
    I love wireless charging. I know people complain it's not really wirelessly, but it's so mindless to just set it down on the charger. My phone is always charged and ready to go each day!
  21. #21
    I've had my Orb for a week; until two days ago it was fine, and then my naked phone began sliding off at night. It woke me up the first time with the low battery sound. I run Gentle Alarm as my clock at night, and I had to turn it off in order to stop the low-battery/now your phone is charging sound. The charge was too low to compete with the clock app. I read what I could for solutions, and yesterday cleaned the Orb with sticky packing tape. It didn't help. I ended up propping the base of the Orb in the front with a cloth to reduce the angle. My phone stayed put last night but that's not how I want to be using the Orb. I've read that a back screen protector helps. Maybe I need to also focus on cleaning the phone's back as well as the Orb. It's a pain. At least the TYLT charger I pre-ordered won't have that problem, but I would like the Orb to work, too.
  22. #22
    worknman's Avatar
    Posts
    Global Posts
    49 Global Posts
    Here's the Nexus 4 slippage in action:
  23. #23
    Quote Originally Posted by KathyJN View Post
    Same with me. My N4 stuck tight to the orb for about a week, and now it slips off overnight, too. Really disappointing.
  24. #24
    bearda's Avatar
    Posts
    Global Posts
    93 Global Posts
    That's exactly what happened to mine before I sent it back. Been waiting a week for a replacement now.
  25. #25
    This sounds like too much work just to charge. I love my lg wpc -700 charging MAT. No fuss, just kay it down and charge it
    Sent from my SAMSUNG-SGH-I317
    Galaxy S4 (32GB), Galaxy Note 2 (AT&T), Nexus 4 (16GB), Nexus 7 (32GB)
    and yes...an iPhone 5 too...
  1. constant wireless charger message
    By pfame5 in forum Verizon LG Revolution
    Last Post: 11-11-2012, 03:36 PM
  2. Wireless charger?
    By Vikman in forum Samsung Galaxy S3
    Last Post: 06-10-2012, 09:38 AM
  3. Wireless Charger Review? Have a pinch of salt handy...
    By Nashstruck in forum Samsung Galaxy S3
    Last Post: 05-21-2012, 02:58 PM
  4. New USB port or Wireless Charger?
    By sandman1887 in forum Verizon HTC Thunderbolt
    Last Post: 01-31-2012, 06:20 PM
  5. Wireless charger/extended battery/window mount/bluetooth FM transmitter
    By RandyVanF in forum Thunderbolt Accessories
    Last Post: 03-29-2011, 09:19 AM
