Results 1 to 10 of 10
    Default No Sound Notification When Wireless Charging Starts
    When I put my N4 on the wireless charging orb, there's no sound to let me know it's working. I have to look at the phone to see. I'm on 4.2.2 (and Paranoid Android), so there's supposed to be a sound. Am I just missing a setting somewhere?
  2. #2
    Default Re: No Sound Notification When Wireless Charging Starts
    I'm stock and it makes a cool beep tone. But it's hit or miss. Most of the time it does.
    Run, do NOT walk, and get a Nexus 7. You can thank me later.
    Palm IIIxe, Handspring Prism, Sony CLie, Tapwave Zodiac, Centro(AT&T), Palm Pre Plus(AT&T), Nook Color, HP Touchpad-32, HP Veer, Samsung Galaxy Note(AT&T), Nexus 7 (32), Nexus 4 (16)
  3. #3
    I've noticed it only sounds when you have it off the charger or a while and then set it down. It doesn't seems to do it if you return it there less than 30 mins or so later. And I kind of like that it doesn't annoy you if you are just using it at your desk and want to pick up for a call and then immediately back down.
  4. #4
    I get the notification sound from my N4 and a beep from my LG charging mat.
    Galaxy S4 (32GB), Galaxy Note 2 (AT&T), Nexus 4 (16GB), Nexus 7 (32GB)
    and yes...an iPhone 5 too...
  5. #5
    I get no beep using the Nokia charger
  6. #6
    Hit or miss for me using the Zens charger. Sometimes, I get the sound notification. Sometimes, I don't. Regardless, the Zens charger illuminates a blue LED letting you know it's charging.
    http://www.shopandroid.com/zens-wire...A233A12862.htm
  7. #7
    TrekMD's Avatar
    Posts
    Global Posts
    533 Global Posts
    I've noticed that I only get the sound if I set the phone on the wireless charger with the screen off. It never happens if the screen is turned on.
    I choose Android...it's only logical.
  8. #8
    Phil put a blurb up awhile ago on how to change the charging sound. My search fo is weak. Anyone?
    As the OP, I want to update this thread that the sound started appearing for me after a later update to Paranoid Android. I'm currently on 4.2.2 and PA 3.10 and the phone makes the noise when placed on the orb charger.
  10. #10
    Has there been a solution without changing anything? running stock and notice it is randomly happening as well. Once I restarted the phone, it was making the sound again.
  1. D4 no sound when in car dock
    By DERacing in forum Motorola Droid 4
    Last Post: 11-06-2012, 09:30 AM
  2. No sound when txting!!! Help!!
    By PunKPwnZoR in forum Verizon HTC Thunderbolt
    Last Post: 12-13-2011, 07:37 PM
  3. No sound when watching Green Hornet 3D?
    By jsorryman in forum HTC EVO 3D
    Last Post: 08-29-2011, 09:50 PM
  4. no sound when touching screen
    By ryken229 in forum Motorola Xoom
    Last Post: 04-05-2011, 08:06 PM
  5. No sound when i receive a text?
    By ilhan80 in forum HTC EVO 4G
    Last Post: 03-02-2011, 07:24 AM
