Thanks peejay.. I'll add a link to your post in the OP drivers section later
Hey 2def, finally got my N4 ordered today. Got a quick unlock question...Should I turn the phone on for the first time and unlock it right then, or do you activate it first, then unlock? I know that unlocking wipes everthing, but I wondered if you needed to activate first.
Grey
This is probably stupid, but in your instructions under the tab Re: PC/MAC/LINUX, it seems like you're saying that on a Windows PC (I'm running Windows 7), you need to type fastboot-windows blah, blah, blah, but then in your Unlocking the Bootloader tab, you just show yourself typing "fastboot oem unlock"
So my question is, do I need to type "fastboot oem unlock" or "fastboot-windows oem unlock" (minus the quotes)?
You type the version that is specific to what OS and fastboot file you are using, in this case, fastboot-windows. When you download the package there are 3 fastboot files in there: fastboot-linux, fastboot-windows and fastboot-mac.. the first word in your command tells your computer what file to reference when carrying out the command. So, when you type:
You are telling your computer to reference the "fastboot-windows" file in the directory you have pointed your command prompt to, and to carry out the "oem unlock" command which that file knows how to do.
Make sense?
Need a bit of a help here for someone who is new to android, thanks!
I rooted my n4 using the method described by the OP on stock rom. Today I received the OTA update for 4.2.1 and updated, only later found out I have lost my root (as titanium backup could not backup).
What should I do now? Am I screwed?
I heard someone said something about voodoo root keeper, what is that? I will that help?
Thanks guys.
If you update to 4.2.1 then unlock it, will it go back to 4.2?
I have windows 7 machine and the commands are not recognized when I trype them. What am I doing wrong?
The fastbboot devices command does not work for me.
@handku... The sdcard gets referenced under a few identities, such as what you found as well as /data/media... In general I'd say don't just go around deleting things from anywhere, lol.. But you can use good judgement and remove things from there if you must. Any app info being stored on that partition is probably needed for the app to function and relatively insignificant in size so it's best to leave it alone tho.
