04-07-2014 10:11 PM
303 ... 56789 ...
tools
  1. 2defmouze's Avatar
    I'm having some trouble with rooting the phone,I've unlocked it and I typed in "fastboot-windows boot recovery.img" in the command prompt and keep receiving the message "cannot load recovery.img"
    Check that you renamed the file correctly. If windows kept the .img extension hidden you may have only needed to name it "recovery".
    01-03-2013 06:14 AM
  2. CommanderBob22's Avatar
    Renaming it worked. Thank you so much for this guide!
    01-03-2013 11:18 AM
  3. Evil Betty's Avatar
    Sorry if this has been asked many times...So to make a Nandroid backup with the recovery not permanently flashed, I can go into the bootloader, plug my phone in, do the "fastboot boot recovery.img" then just proceed to the recovery option? Because right now I get the little dude with a red "!"
    01-03-2013 11:42 PM
  4. 2defmouze's Avatar
    Yes, you're seeing stock recovery right now. Boot the custom one temporarily and do as you desire
    01-04-2013 05:01 AM
  5. Evil Betty's Avatar
    Ok sounds good. And thanks for putting together the guide. It's nice having all the files needed together in one place and it was very easy to follow.
    2defmouze likes this.
    01-04-2013 11:45 AM
  6. 2defmouze's Avatar
    No problem, good to hear you got everything you need!
    01-04-2013 11:50 AM
  7. corance's Avatar
    Where can I put titanium backup so I don't lose it when I flash a ROM? I hate having to download it again to restore my backups. Also, is there a way to make the backup of my apps smaller? Like a zip or something so my backup isn't taking up 1 gig of space?
    01-04-2013 03:45 PM
  8. 2defmouze's Avatar
    You can create a zip within TiBu to flash after the ROM, so it will be installed when you boot up. Check the link in my signature to the TiBu guide I wrote
    01-04-2013 04:10 PM
  9. Evil Betty's Avatar
    Maybe shouldn't belong in this thread but hopefully someone can help. I downloaded AOKP and the Gapps packages from here ([ROM] [4.2.1] AOKP :: jb-mr1 :: build-1 :: mako - xda-developers) and flashed AOKP and then Gapps. Everything seems to be fine except the Google apps aren't there. Play Store, Gmail, and Messaging are there but that's about it. I tried doing it twice, wiping/factory reset each time and same thing. Any ideas? Is there any difference just downloading them manually from the play store?
    01-04-2013 05:14 PM
  10. 2defmouze's Avatar
    The gapps packages don't include apps available in the Play Store, helps save space.. You can just download and install them from the Store
    01-04-2013 06:07 PM
  11. corance's Avatar
    You had better luck than I had. I got everything installed but I couldn't get a data connection. I did the APN settings the same and rebooted but still no luck. Any ideas?
    01-04-2013 06:10 PM
  12. Whovian13's Avatar
    i can't get fastboot to rercognize my device (step 4, unlocking the bootloader) i have usb debugging enabled and have re downloaded the files a few times, is there an easy way to get the fastboot to recognize my device?
    01-04-2013 10:11 PM
  13. 2defmouze's Avatar
    Make sure you are entering it for your fastboot file and system, i.e. fastboot-windows or fastboot-mac.. The instructions are general but the 3rd tab I believe explains what I mean.
    01-05-2013 09:19 AM
  14. jamesgs's Avatar
    Hi 2defmouze,
    Thanks for the guide - simpler than all the others I have found
    I still get stuck, however, when trying to root. I run ubuntu 12.10 and have tried 5+ different guides out there so far with varying success.
    Managed to oem unlock no problem. I get stuck with the rooting, as follows:
    Code:
    $ fastboot boot recovery.img
    < waiting for device >
    I'm in bootloader on my nexus 4 and placed recovery.img both in /usr/local/android-sdk/platform-tools (where the script installs it) and Nautilus pushed it to the sdcard. fastboot just hangs there doing nothing. Tried sudo and...
    Code:
    cannot load 'recovery.img'
    So, I stupidly thought that ADB and fastboot weren't set up properly and ran the script you linked to earlier in the thread at rootz wiki. Still get the same problem but now 'adb devices' and 'fastboot devices' don't list my device Any ideas? Been at this for over 24 hours now - any help would be truly appreciated.
    Many thanks,
    James
    01-05-2013 03:01 PM
  15. jamesgs's Avatar
    Hi again,
    Ignore my last post. Quicker and faster using this: CF-Auto-Root
    Did the whole thing in a matter of seconds - worth checking out
    Cheers,
    James
    01-05-2013 03:29 PM
  16. John-Smith's Avatar
    VERY VERY Good writeup. Quick and easy. Had my N4 unlocked and rooted in less than 20 minutes. Awesome job guys!! Thank you!
    01-05-2013 11:19 PM
  17. CrazCruz's Avatar
    Question here defmouze, I unlocked main with the xda toolkit but I don't know how to install a custom recovery myself without rooting. Is in the Root it! tab but still don't know how.
    01-07-2013 02:43 PM
  18. 2defmouze's Avatar
    You can boot into the custom recovery with:
    Where "recovery.img" is replaced with the name-of-recovery.img if it's different, or you can rename the recovery image to recovery.img. To flash it permanently you need to rename or delete the file recovery-from-boot.p from /system. I believe there may be another file to alter as well.
    CrazCruz likes this.
    01-07-2013 08:14 PM
  19. Trance128's Avatar
    Just want to say thanks for posting this. Great help for an android newbie like myself.
    01-22-2013 10:33 AM
  20. DeadpoolJunior's Avatar
    I keep getting a "cannot load recovery.img" prompt when in fastboot. I dont know what to do from here.
    EDIT: Nevermind, I figured it out. You should really consider going back and editing the step where it says rename the image file to "recovery.img" because thats what I named it and thats why I was having issues. It should just be named "recovery" and when you enter the "fastboot boot" prompt, thats when you add the .img to it. I read that wrong and i'm not sure if anybody else might have had that issue (or if im just an ***** lol)
    01-24-2013 02:44 PM
  21. 2defmouze's Avatar
    That's really only a concern in Windows if you have it set to not show file extensions when renaming them, AFAIK. Many people change that setting, and those who haven't usually figure that part out... but maybe I'll add something to note that in the OP..
    01-24-2013 04:47 PM
  22. DeadpoolJunior's Avatar
    Yeah no worries. Like I said in the post, I may just be an ***** on that one lol
    01-25-2013 09:15 AM
  23. 2defmouze's Avatar
    Update: TWRP updated to version 2.4.0.0, new direct link in OP.. many improvement and bugfixes, full changelog can be found scrolling down here: TeamWin Projects - TWRP 2.4 - | TeamWin
    As a note, users who are already rooted can save some time and energy updating their recoveries by installing GooManager from the Play Store. Once installed open it and grant it root access. Tap the action bar, followed by Install OpenRecoveryScript. Confirm Yes, and make sure the next box shows the correct file to download and automatically flash for you - it should have the latest version number and 'mako' in the filename. Then just let it do it's thing and you'll be good to go
    01-31-2013 05:21 PM
  24. Bar81's Avatar
    Already updated to 2.4.1.0
    02-01-2013 02:23 PM
  25. AFM1204's Avatar
    Yes, I just tried to get root with 2.4.1.0 and it didn't work. My attempt to boot the recovery.img from this file left me hung up on "downloading 'boot.img'..." Once I deleted this version of recovery.img and created a new one from openrecovery-twrp-2.4.0.0-mako.img, the phone booted up as expected and I was able to flash SuperSU. So stick with 2.4.0.0. Although it may be fine for those who are already rooted.
    02-02-2013 07:17 PM
303 ... 56789 ...
  1. [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexus
    By dmmarck in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 02-26-2015, 06:45 PM
  2. [GUIDE][MAC/PC/LINUX][4.2] Unlock, Root and Flash Recovery
    By zero neck in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 11-14-2014, 01:36 PM
