corance
Maybe shouldn't belong in this thread but hopefully someone can help. I downloaded AOKP and the Gapps packages from here ([ROM] [4.2.1] AOKP :: jb-mr1 :: build-1 :: mako - xda-developers) and flashed AOKP and then Gapps. Everything seems to be fine except the Google apps aren't there. Play Store, Gmail, and Messaging are there but that's about it. I tried doing it twice, wiping/factory reset each time and same thing. Any ideas? Is there any difference just downloading them manually from the play store?
You had better luck than I had. I got everything installed but I couldn't get a data connection. I did the APN settings the same and rebooted but still no luck. Any ideas?
