Ice Phrozen
Active member
Hm you'll have to be more specific... see the two parts I bolded above are not really clear to me. Which recovery is not working and which one is? And how are you getting into the one that is working? (I am assuming by flashing it or booting into it from fastboot but need to clarify..)
It's possible that recoveries (either/both CWM and TWRP) need updating for the new system.. haven't heard of that myself yet but stranger things have happened. But yeah in any case you can see from his G+ post that Koush is working on the superuser issue still, so you would have to wait anyway before rooting 4.3 unless you want to use SuperSU.
Personally I'm going to be sitting tight until the issues are sorted out or a stable AOKP or CM build for 4.3 comes out (as the custom ROMs can much more easily work around the superuser problem since they are building from source).
Under the "Root It" tab of your guide, and following the steps to BOOT recovery.img via flashboot results in me rebooting into a black screen, and it just stays like that.
To get around this, I powered off the phone, booted into flashboot, and instead of booting in flashboot, I FLASHED recovery.img (flashboot flash recovery recovery.img). Launched the recovery (by selected it via the volume rocker), and flashed superuser.zip from there.
Just trying to understand why booting recovery.img via flashboot, as it's listed in your guide, isn't working for me.
Thanks.
