[GUIDE] Nexus 4 - Unlock & Root
Nexus 4 Unlock and Root Guide
Re: [GUIDE] Nexus 4 - Unlock, Flash Recovery, Root
looks dope.
however, i think the closing section should be changed to say "shout out my boy zero neck wihtout you i'm just an empty husk"
because it would be incredibly classy.
Quote:
looks dope.
Ya know that was in the first draft, not sure why I even changed it.
Your guides are awesome. Thanks, now I just need a Nexus 4 and I'll be all set :-)
Thanks for this great guide.
I seem to be lost in one spot though. In the "Recovery and Root" stage, on step 3, I don't see any where to tap "install zip from SD Card". Where should I be seeing that?
In my command prompt window, I have:
Sending 'recovery' <7628 KB>
OKAY
Writing 'recovery'
OKAY
Finished. total time: 0.905s
So it would appear that I have done the previous steps correctly, but I'm not understanding what I need to do next. Sorry for asking a lot of questions, I'm a complete newb at this.
UPDATE:
I used "fastboot boot cwm-recovery-mako.img" and I now see the option to install zip from sd card.
I now have a niffty Super SU icon :)
Pardon my possible rudeness; but doesn't needing to root, unlock, etc totally defeat the point of getting a Nexus device? Though I know most of it is to be able to flash Roms...
Maybe I'm just old school... Sorry lol
Same here! T-Mobile rep was going to hook me up with a discounted S3 on 2-Year contract but I can wait. I'm so grateful for this guide, OP! THANK YOU!
Not at all.. Nexus devices are made to be easily unlocked, rooted and tinkered with, but of course you don't have to.
Flashing ROMs is one great thing to do, but not the only. Myself for example, I'm planning on staying on stock for at least a little bit before flashing on my Nexus 4, but I still have reason to root. I'm going to be using Titanium Backup to restore my apps and games data from my Galaxy Nexus to the Nexus 4 first off. Might use an ad blocker as well. Just a quick example.. But there are other reasons one may desire to unlock and root that don't always involve roms, although roms are a great option to have, even on a Nexus.
I just want to be able to root the phone but also receive OTA updates like I do on my Nexus 7. I didn't flash CWM onto my Nexus 7, only unlocked and rooted, I didn't see that option for the phone yet, as there's a step to flash CWM..is this always needed?
The step included will not flash CWM, just boot you into it so that you can flash su. Your stock recovery will remain intact and you'll get OTAs assuming you don't change the system. You will likely lose root after an OTA unless you use OTA Rootkeeper, or else you can just reroot it just like the first time. :)
Amazing guide this will definitely come in handy...once I have my n4:D:thumbup: although it may take me a while to get the money I need together...
Just a quick question, the Universal drivers don't support right-click and Install so is there an accepted method to force them to install? I have copied stuff to the INF folder in Windows before but I'm just mindful that uninstalling the drivers, rebooting will then reinstall the drivers that Windows wants to without prompting for a user location. I would normally have gone into Device Manager, right-click the device and chosen Update Driver and then pointed it manually to the driver location.
Not being pedantic, I haven't even got my Nexus 4 yet but just pre-empting a possible hurdle/question.
Thanks
Thanks
Hmm.. I'll have to look into that when I get a chance.. I am spoiled by using Ubuntu as my primary OS so I don't worry about drivers, lol.
I'll see if I can get that clarified for you, and in the meantime if you are able to find an answer on your own please share it here and I'll be sure to make a note in the guide :)
In fairness I could dual boot with Ubuntu but I'll see what happens when I (eventually) get mine :)
That would be my recommendation ;)
I have dual-boot setup for Windows 7 and Ubuntu.. but as time goes on I use my Windows partition less and less, lol. Ubuntu ftw!
I thought the same but video editing is far easier in Windows, I'll get it working, considering I've worked in IT for 17 years I'd rather hang myself than admit defeat! Lol
Re: [GUIDE] Nexus 4 - Unlock & Root
Cleaned up some stuff, updated the CWM link to Koush's official build, added a few things to the FAQ....
Everyone finding things understandable, easy to follow, etc? I'm always open to suggestions and questions! :)
Thank you this is perfect. Now I just need the phone. :-)
You and me both, lol :)
Quick update.. the Universal Drivers pack was updated to 0.72 so I updated my dropbox and the link. Afaik the only change is that these drivers will support the Nexus 10 as well, so the 0.71 ones should work fine on the Nexus 4 if you already grabbed those, but I figure it's best to just keep everything updated anyways :)
Yeah, I hope my shipping estimate never changes from Nov 15th, even after I get the phone, it'll serve as a nostalgic reminder of this week.
Lol mine is on the way, should be here monday :)
Koush updated the recovery to version 6.0.1.8... presumably squashing some bugs. I updated the link in the OP - everyone please be sure to use the latest version! :)
Nice one, I'll let you know how I get on with the Windows unlocking when I finally get the phone. I might record the screen just in case it helps anyone else and get the GoPro setup to record the phone.
Sent from my iPad using Tapatalk HD
And again Koush pushed an update.. 6.0.1.9 linked in the OP :)
