Results 1 to 7 of 7
    Default Root Fail using Nexus 4 Toolkit
    N4 running 4.2.1
    Nexus 4 Toolkit version 1.3.01
    Windows 8
    I was able to unlock the bootloader using the Toolkit.
    When I try to Root using Toolkit option "Root Device + Install Busybox" [Fastboot Mode] the Toolkit tells me "Waiting on Device" forever. It does nothing. Yes...I have the N4 in Fastboot mode and it is plugged in to the pc.
    Any idea what I'm doing wrong?
    Joey
  2. #2
    Default Re: Root Fail using Nexus 4 Toolkit
    Can you download busy box from the market and try install that way if that works it will confirm a successfull unlock and confirm device is ready to be rooted?
    I do believe reading windows 8 had device signature problems
    Either use a different OS or try the fix
    [GUIDE] Nexus 4 - Unlock & Root
    I followed those instructions and I unlocked and rooted fine
    Using windows 7
    Quote Originally Posted by Fraser Carter View Post
    Using windows 7
    Yes, I downloaded and installed Busybox from the Play Store.
    Upon opening Busybox I get the message "There was a problem opening a shell with root access. This is either being by Super user/supersu or by a device that is improperly rooted."
  4. #4
    I think the latest version of the toolkit is 1.6.1. Which added support for the Nexus 4.
    I've used that on Windows 8 to unlock a N7 and a Gnex many times.
    Nexus 4 / Stock | Nexus 7 / Stock | TFPrime / Hairy Bean 2.1.1
    @digitalslacker
    +digitalslacker
    It must've been a Windows 8 thing. I was able to do it on my Win 7 machine. Thanks.
  6. #6
    Yes, there is driver signature problems with windows 8.
    Glad you got it to work!
  7. #7
    Never had a driver problem on windows 8. Been using the preview for months and did a clean wipe when the msdn version was released. But who knows, windows isn't known for being driver friendly.
    @digitalslacker
    +digitalslacker
  1. 1 Clck rooting, anyone used it yet?
    By Kronko in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 03-27-2011, 08:49 PM
  2. should i root and use custom rom?
    By kofman13 in forum Virgin Mobile Optimus V
    Last Post: 03-17-2011, 10:25 AM
  3. Being able to root or use the g1 without a SIM card help?
    By yus4eel in forum Software Development and Hacking
    Last Post: 07-12-2010, 05:02 PM
  4. Help with clean reset of used nexus
    By scaots in forum Google / HTC Nexus One
    Last Post: 07-05-2010, 09:14 AM
  5. Replies: 2
    Last Post: 03-26-2010, 08:33 AM
