Results 1 to 13 of 13
Like Tree5Likes
  • 1 Post By 2defmouze
  • 1 Post By NotJustAPhone
  • 2 Post By 2defmouze
    rdogger's Avatar
    Posts
    Global Posts
    95 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Android OS battery drain
    I was running an AOKP nightly no battery drain or troubles. Decided to flash Franco's kernel, after a while noticed my battery was draining rather quickly, looked and android os was way out of control. Got the newest AOKP nightly and clean flashed, problem was still there. Flashed the newest franco nightly and still happening. The phone is not going into deep sleep. No change in use or apps. Any ideas or anyone else having this problem?
  2. #2
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Default Re: Android OS battery drain
    I would blame an app you have. I'm on the aokp 12/8 nightly and having no problems getting into deep sleep (screenshot shown).
    Stock kernel.
    Attached Thumbnails Attached Thumbnails Android OS battery drain-uploadfromtaptalk1355175576296.jpg
    NotJustAPhone likes this.
  3. #3
    NotJustAPhone's Avatar
    Posts
    Global Posts
    11,776 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    GS3: CleanROM / N4: AOKP
    Running 12/8 nightly with stock kernel and not having any problems with the phone entering deep sleep. Try something like Better Battery Stats and see what's keeping your phone awake.
    Sent from my Nexus 4
    2defmouze likes this.
    rdogger's Avatar
    Posts
    Global Posts
    95 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is what I thought as well. When I flashed last night I did not install any apps to see if that was the problem. Still not getting into deep sleep.
Name:	2012-12-10 15.41.25.png
    rdogger's Avatar
    Posts
    Global Posts
    95 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Going to do another clean install, trying a different gapps package, had been using an older one that was working fine. Maybe something with it was running out of control? Only thing I can think of, will report back.
  6. #6
    Posts
    Global Posts
    11,776 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I flashed the 11/30 Gapps package.
    rdogger's Avatar
    Posts
    Global Posts
    95 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Any chance this could be a hardware issue? I flashed the stock image and the android os was still eating the battery. No apps installed, I am out of idea's haha.
  8. #8
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Quote Originally Posted by rdogger View Post
    You're probably not giving the system and kernel time to settle nor the battery time to calibrate. After any flash you need to wait a few days or charge cycles before those stats will approach normalcy.
    rdogger's Avatar
    Posts
    Global Posts
    95 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree I'm not letting it set but this drain is new to me so I am overreacting a bit haha. I downloaded Better Battery Stats, what should I look for after I give it a day or two? Never used it, always had good battery life with my Gnex and S3 and flashed the crap out of both of those.
  10. #10
    Posts
    Global Posts
    11,776 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by 2defmouze View Post
    ^This.
  11. #11
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    After appropriate time for settling and calibrating, charge it full and leave it overnight unplugged on wifi only. Typical drain should be between 1 and 2% per hour... If it's more than that, then you can worry about it.
  12. #12
    Russ Dill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What app is this?
  13. #13
    ConTejas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Latest OS + EX kernel
    The screenshots above are from AOKPs built in performance control, but it's essentially cpu spy.
  1. "Android OS" Battery Drain Issue in ICS
    By TouchWizard in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-26-2013, 12:04 AM
  2. Android OS battery usage is higher than screen usage?
    By briansmithphotography in forum AT&T Galaxy S3
    Last Post: 08-17-2012, 03:29 PM
  3. Android OS is draining my battery fast.
    By skulldroid67 in forum Samsung Galaxy S II
    Last Post: 01-27-2012, 06:48 PM
  4. Android OS battery usage
    By astraelraen in forum Verizon Galaxy Nexus
    Last Post: 12-20-2011, 02:01 PM
  5. Android OS battery usage
    By gmichie in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-19-2011, 01:16 PM
