- 12-28-2012, 09:09 PM
Thread Author #1
- 12-28-2012, 09:19 PM #2
- 12-28-2012, 09:32 PM #3
- 12-28-2012, 09:41 PM #4
Re: Nexus 4 Screen is washed out Fix
I tried it and refunded it; it's too limited.
There's a massive thread at XDA with an accompanying spreadsheet of settings from people using an app called (it's $4) which is a kernel tweaker and does a bunch of other stuff, but also accesses the color settings - not only the usual RGB, but two sets of gamma amps for a total of 9 controls. There's a lot of discussion and my massive post discussing my issues with the N4 screen and the settings I used is here:
You need to be rooted, but it works with the stock kernel (which I have) and to get gamma changes to register, you need to shut off the screen and turn it back on; a slight hassle, but wah, First World Problem. People use to check gamma. It's a free app (with Pro version available which takes out the splash screen delay), but tends to crash a lot, especially when doing the gamma stuff."The Nexus 4 is such a big black slab of power that if you dropped it down in the middle of a pack of monkeys, they'd start using weapons." - Dirk Belligerent. - 12-28-2012, 11:05 PM
Thread Author #5
Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 12-28-2012, 11:08 PM
Thread Author #6
Dirk is definitely into it more than I am. I didn't hate the display so a few tweaks was all I needed.
Sent from my Nexus 4 using Android Central ForumsAndroid Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 12-28-2012, 11:15 PM #7
- 12-28-2012, 11:47 PM #8
- 12-29-2012, 12:07 AM
Thread Author #9
Not that I could find.
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 12-29-2012, 12:48 AM
Thread Author #10
Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 01-09-2013, 12:58 AM #11
Bumping this up because a user on the XDA thread, MasterJam882, submitted these settings and I think they're the best yet for my phone. Give 'em a shot if you're rockin' the FauxClock beats:
Settings:
All stock, stock kernel, just FauxClockApp
LG presets
R: 255
G: 255
B: 255
AMP1
R: 24
G: 22
B: 21
AMP2
R: 0
G: 0
B: 0"The Nexus 4 is such a big black slab of power that if you dropped it down in the middle of a pack of monkeys, they'd start using weapons." - Dirk Belligerent. - 01-09-2013, 01:33 AM
Thread Author #12
Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 01-09-2013, 02:22 AM #13
Just be rooted (natch) and after making gamma changes, you must cycle the screen off then on for them to take effect. Color changes occur in real time.
"The Nexus 4 is such a big black slab of power that if you dropped it down in the middle of a pack of monkeys, they'd start using weapons." - Dirk Belligerent. - 01-09-2013, 05:19 AM #14
My Nexus 4 is still a few weeks away. Has anyone created a before and after video or screenshots of this fix?
It sounds really interesting and it would be my only reason for rooting. I just wanted to make sure that it is worth the effort. - 01-09-2013, 09:43 AM
Thread Author #15
Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 01-09-2013, 10:32 AM
Thread Author #16
I did some fiddling and am using these settings with Faux clock. Your settings seemed too blue and the gamut was too dark for my phone. I was losing darker grays.
R255
G247
B225
#1
28
29
31
#2
17
17
17
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 01-09-2013, 09:27 PM #17
Your settings are WAAAAAAAAY too bright. The AMP2 gamma makes dark areas in my photos so bright that it's really shocking the difference it makes. I'd just put together a gallery of favorite photos I've taken from my Flickr so I could check settings against photos I'm really familiar with and your settings radically affected how they looked. They didn't wash the colors out as much as flatten the contrast between foreground and background objects so they didn't pop the same way.
Did you check the gamma of your settings? My latest aren't exactly 2.2 for everything, but most of the sins of the panel in rendering skin tones have been mitigated."The Nexus 4 is such a big black slab of power that if you dropped it down in the middle of a pack of monkeys, they'd start using weapons." - Dirk Belligerent. - 01-09-2013, 09:32 PM
Thread Author #18
Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 01-11-2013, 02:05 PM #19
- 01-12-2013, 03:40 AM
Thread Author #20
Android Evangelist
Reply
