1. lombardian1's Avatar
    Hi i'm new here. I was using my phone regurarly (a lg nexus 4) and i blocked it up, and when i tried to unblocked it my lock screen have had changed, it was smaller, the pattern were at the right size minimized and the widgets were in sort of a cube, i really liked it but when i unblocked and blocked it again it was gone, it was the normal lock screen. How can i make that happen again?
    01-22-2013 10:00 PM
  2. Lanhoj's Avatar
    Not quite sure what you mean...you have a Screenshot?
    01-22-2013 10:15 PM
  3. Patrick Schroedl's Avatar
    That sounds very much like the tablet UI lockscreen to me. At tablet display sizes, the lockscreen challenge (circle, pattern, PIN, etc.) appear on the right half of the screen and lockscreen widgets appear on the left half (with a carousel animation that could be described as cube-like). There are mods out there that you can flash to your phone (assuming it's unlocked, rooted, and running a custom ROM that would be compatible with such a mod) which will enable tablet mode.
    Some ROMs also come with tablet-style UI built-in, but I can't say offhand whether any ROMs or mods are available yet for the N4.
    01-23-2013 01:15 AM
  4. 2defmouze's Avatar
    Sounds like AOKP lockscreen options to me.. They have the option for the widget carousel, minimizing lock challenge on wake up, and more..
    Attached Thumbnails Nexus 4 lock screen style-uploadfromtaptalk1358940739902.jpg
    01-23-2013 05:32 AM
  5. lombardian1's Avatar
    Do you have a link for that? for the AOKP lockscreen
    01-23-2013 03:26 PM
  6. lombardian1's Avatar
    01-23-2013 06:55 PM
  7. 2defmouze's Avatar
    AOKP is a ROM, like Cyanogenmod. AOKP and CM are probably the only stable ROMs I would recommend. You can get the ROM from their official site if you want the latest stable build: Releases | AOKP
    Some of their dev team pumps out newer builds more often that you can find on sites like XDA and Rootzwiki, but the official ones will be the most stable. If you are new to flashing ROMs and stuff like that I'd highly recommend reading a guide like this one that was written for the Galaxy Nexus: [GUIDE] Don't Panic: The Hitchhiker's Guide to the Galaxy Nexus
    Along with other info you can find. You can ask any specific questions you've got in this forum. Just read that for the concepts, obviously the specifics will pertain only to the GNex but there is a lot of good info in there for a beginner.
    01-24-2013 03:56 PM
  1. Nexus 7 on 4.2: N Available Lock Screen Widgets (or list not displayed?)
    By dbareis in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-23-2013, 08:35 PM
  2. Customize Nexus Lock Screen and Home Screens
    By DeathByBFG in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-25-2012, 05:21 PM
  3. AT&T Nexus S ICS lock screen icon question
    By ncrichert in forum Android 4.0 Ice Cream Sandwich
    Last Post: 08-04-2012, 03:56 PM
  4. AT&T Nexus S ICS lock screen icon question
    By ncrichert in forum AT&T Nexus S
    Last Post: 08-02-2012, 08:58 PM
  5. Adding New Lock Screen Styles
    By Dugoutdog in forum Rezound Rooting, ROMs, and Hacks
    Last Post: 03-21-2012, 10:59 AM
