DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 10 of 10
    Default Cyanogenmod 10.1 M2 with Matrix kernel, safe and will I see better battery life?
    Right now I only get 2 hours on screen time with cyanogen mod and just keep on hearing how great matrix kernel is, is this true?
  2. #2
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default Re: Cyanogenmod 10.1 M2 with Matrix kernel, safe and will I see better battery life?
    Battery life is affected by a number of things, for example: kernel and kernel settings, signal strength throughout the day, apps installed, apps being used, screen brightness level, the ROM you are running (to a small extent), active/disabled sensors, and the list goes on. As you can probably guess, the respected kernel developers (of which I would say the CM team has a lot of experience) do not design their kernels to give poor battery life, in fact usually they work hard on improving it. More often than not, a user who's battery life is poor is due to one or a combination of the other factors.
    This is not to say that trying a new kernel won't help you, it might. But it's important to consider the other factors and whether there are other options you could try out to improve it.
  3. #3
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Other things to consider... Any new ROM or kernel flash means you need to wait a few days for the battery to calibrate properly before you can judge the batt the life (it will do this on its own through normal usage).
    And if you want to try a new kernel you don't need to stress it too much.. Just flash it. You can swap kernels out easily if you change your mind later.
    Quote Originally Posted by 2defmouze View Post
    Yeah after giving Cyanogenmod some more time I see a BIG increase in on screen time I think the team behind cyanogen have done a wonderful job! Although the inner geek in me still wants to flash the matrix kernel lol
  5. #5
    Quote Originally Posted by Chetan Takyar View Post
    Give it a try. As 2def said, flashing a kernel is quick and easy. Some people like to wipe cache and dalvic (no data wipe needed), some wipe nothing and just flash the kernel. Matrix runs great, so does Franco.
    Semper Fi
    I love my LG Nexus 4!
    Quote Originally Posted by greydarrah View Post
    Wait so I don't have wipe anything of my phone before flashing a kernel?
    - - - Updated - - -
  7. #7
    A lot of people wipe absolutely nothing when only flashing a kernel. I always wipe cache and dalvik. It just takes a minute to wipe and maybe an extra 2 minutes when it boots back up. But you definitely do not need to wipe data to flash a kernel.
    Semper Fi
  8. Thread Author  Thread Author    #8
    I've been lied to so for so many months,...
  9. #9
    Just to be clear...If you are flashing a ROM, you DO need to wipe data (this is probably what people were were referring to), but not if you are flashing just a kernel.
    Semper Fi
  10. Thread Author  Thread Author    #10
    Yeah I've already got Cyanogenmod flashed so I don't have to wipe it.
  1. CyanogenMod 10.1 nightlies for the Verizon and Sprint Galaxy Note 2 now available
    By Droid_Evo_8 in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 02-07-2013, 11:24 PM
  2. CyanogenMod 10 Nightly & M Build Change Log and Bug List
    By dano92580 in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 09-25-2012, 12:18 PM
  3. Do You Text and Want Better Battery Life?
    By MrObvious in forum HTC Droid Eris
    Last Post: 08-21-2010, 11:04 AM
  4. Replies: 4
    Last Post: 07-19-2010, 11:06 AM
  5. Better Battery life with 6/28 update?
    By Holsum in forum HTC EVO 4G
    Last Post: 06-28-2010, 01:34 PM
