1. Mastaking's Avatar
    I am trying to sift through the internet for this but if anyone has done it successfully can you please post steps and zips. Thanks.
    07-31-2013 03:35 PM
  2. digitalslacker's Avatar
    maybe this?
    *UPDATED* [ZIP] All in One LTE Enabler, Flash ONE zip, and have BAND 4 LTE on any ROM - xda-developers
    haven't tried yet. I installed an LTE enabled unofficial CM 10.1 and then dirty flashed the nightlies and it seemed to stick but i'm looking to bump up to 4.3
    xdalaw likes this.
    07-31-2013 04:56 PM
  3. digitalslacker's Avatar
    Working well for me on .33/.84 running stock 4.3
    just gotta manually setup the APN
    and i'ts pretty cool that they make the changes persist after a ROM update so if i move over to nightlies of something it'll keep apply with easy flash automagically.
    07-31-2013 07:09 PM
  4. Khurram Saleem's Avatar
    Hi,
    Im new to all this so have a question.
    I have unlocked the bootloader. And downloaded the zip file. What commands do i use to apply them?
    thanks,
    KS
    08-04-2013 02:02 AM
  5. digitalslacker's Avatar
    You flash them via a custom recovery... You'll need to read the sticky guide on how to root and hack
    Sent from my Nexus 4 using Tapatalk 4
    08-04-2013 08:41 PM
  1. Will T-Mobile's 2.5 GB data plan be enough?
    By F0REVERY0UNG- in forum T-Mobile Samsung Galaxy S4
    Last Post: 08-23-2013, 01:48 PM
  2. Help Me Convince UAG to Create A Galaxy Note 8 Case
    By harryhoudini66 in forum Samsung Galaxy Note 8.0
    Last Post: 08-06-2013, 03:28 PM
  3. New to the Samsung and Android Family
    By barner04 in forum Samsung Galaxy S4
    Last Post: 08-04-2013, 09:55 PM
  4. Verizon Galaxy Note 2 : Front facing camera issues on beans build 20
    By biggjd69 in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 07-31-2013, 02:48 PM
