1. anon5664829's Avatar
    I'll start off, completely stock but only because I'm waiting for any bug fix updates to be released.
    VDub2174 likes this.
    11-25-2013 05:01 AM
  2. rupam95's Avatar
    I'm using Franco kernel r194
    11-25-2013 04:43 PM
  3. anon5664829's Avatar
    No current ROM's tickled your fancy.
    11-25-2013 07:53 PM
  4. rupam95's Avatar
    Nope, the stock rom is great.
    11-29-2013 12:19 PM
  5. anon5664829's Avatar
    Yeah but I was thinking of flashing PSX at first then I flashed the Moto X optimised dalvik and performance is just as zippy as it used to be.
    11-29-2013 02:52 PM
  6. someguy01234's Avatar
    I am using MultiROM, which isn't a rom, but a boot manager that allows the Nexus to multiboot into two or more roms installed on the phone. The extra roms are installed in your internal storage and there is no speed lost. It support not only Android, but Ubuntu Touch, Firefox and other OS that work with Linux kernel and ARM.
    For it to work it required applying the MultiROM patch to the main OS. The main OS needs to be running a kernel that support 'kernel execution' (kexec), which "is a mechanism of the Linux kernel that allows "live" booting of a new kernel "over" the currently running kernel." The additional OS runs it's own kernel. It also required a modified MultiROM version of the TWRP recovery in order to install the additional OS'es.
    For more info on MultiROM, see here: http://forum.xda-developers.com/show....php?t=2472295
    I use stock as my main OS, but with a custom kernel that support kexec, then I can install separate custom roms in addition. It's a very good way of testing new roms while still having a stable base to fall back, although I still use a cheaper device as the main calling device, Nexus 4 to do everything else.
    sent from tapatalk
    11-30-2013 07:59 AM
  7. anon5664829's Avatar
    sent from tapatalk
    Oh yeah I know about it. When I upgrade my phone I'll install multiROM on the Nexus 4 to try out Ubuntu Touch.
    11-30-2013 05:30 PM
  8. Hordiyevych's Avatar
    I'm running Beanstalk. Its based of Cyanogenmod 11 and is my all time favourite ROM. Ultimate customisability, and speed. Its great. I'm also using Multi ROM Manager, that's quite cool. My kernel is faux kernel, simply because of the over clocking abilities and the removal of thermal throttling.
    03-16-2014 02:39 AM
  9. leegreg81's Avatar
    That's a kernel, not a ROM.
    05-31-2014 09:29 AM
  10. leegreg81's Avatar
    In my experience it most certainly wasn't. Even after the 4.4 update my N4 had crappy battery life and lacked functionality (such as quick shortcut configuration) that I'd grown accustomed to while using custom ROMs such as CM / Slimbean.
    I'm currently using SlimKat. I prefer it over CM, Purity, Beanstalk and Liquidsmooth. In fact, during my recent installation of Beanstalk 4.4 I suffered with data connection issues and on a few occasions my phone would randomly power down and wouldn't power back up for minutes afterward, although I think this most likely the result of a problem with the Hells Core kernel I replaced the original kernel with.
    SlimKat FTW!
    05-31-2014 09:35 AM
  11. leegreg81's Avatar
    05-31-2014 09:41 AM
  12. sypher770's Avatar
    I am on beanstalk ROM. Its the most full featured 4.4 ROM I know right now. No other kernel seems to work well with it though.
    06-04-2014 03:52 AM
  1. Asus memopad 8 vs Nexus 7 2013
    By bitek in forum ASUS MeMO Pad 8
    Last Post: 08-12-2014, 02:14 AM
  2. Google services are not working with WiFi
    By Alan De Maman in forum Android 4.4 KitKat
    Last Post: 06-30-2014, 05:23 PM
  3. Does your phone play second fiddle to your Nexus 7 LTE?
    By diesteldorf in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-09-2013, 12:37 PM
  4. Anyone use a SIM adapter with their Nexus 7 LTE?
    Last Post: 11-30-2013, 08:37 PM
  5. Audio bugs with nexus 7 2013
    By anonymosu2042 in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-30-2013, 07:07 AM
