I had a battery mod running on 4.3 and it showed percentage, any Xposed module I can install or .zip file I can flash?
KitKat include support for battery percentage in the status bar.
its hidden deep read this Android 4.4 Includes Support For Battery Percentage In The Status Bar – It's Not Ideal, But Here's How To Enable It (No Root Needed)
Battery module for kitkat Enable BATTERY_STATS for KitKat | Xposed Module Repository
if you are looking for xposed modules here is the repository Module overview | Xposed Module Repository
