Boot animation problem.
Waterdroid
111
Hello everyone,
I just tried Boot Animations ★ root (https://forums.androidcentral.com/e...om.jrummy.apps.boot.animations&token=PDFyU92r), and I messed around a little with the animations. Aftter a while I wanted to return to the stock animation so I restored a backup containing my old boot animation (just to be clear, it is just a backup of the boot animation, done in the app itself) and deleted the app. Shortly after I rebooted and found out that I had no boot animation at all, just a black screen. I reinstalled the app and found that the option 'show boot animation' was disabled. Re-enabled, re-deleted the app and rebooted, and now my boot animation is some sort of glowing gray/steel like text saying 'android'. Taking the stock boot animation from the backup, renaming it bootanimation.zip and placing it in /data/local didn't work (I read that on xda somewhere). I also tried flashing a stock boot.img, but with no effect. Probably because the boot animation is not in boot.img, I have no idea where it is located.
Someone please help, this all woulnd't have happened if that crappy app just restored as if it's supposed to do with a backup.
Thanks in advance,
Brian
someguy01234
1,813
boot.img is the kernel.
Just uninstall the app because you don't need it. The system location of bootanimation.zip is in /system/media. Put it there. You need to fix the file permission to be readable after you paste it there, set the file permission to rw - r - r, otherwise known as 644.
If you have no bootanimation at all, it will revert to Android's default which is the "Android" text animation, that's what I use.
sent via tapatalk
tress
