Results 1 to 2 of 2
    mosesx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question How do I fix the Proximity Sensor issue?
    My screen goes blank when I try to use a phone app to make calls.
    I tried to fix it using some proximity sensor apps but it can make it worse. So I have to press the power key and volume down key to go into the bootloader just restart everything so it gets back to normal.
    Both my nexus 4 phones have the same problem, and a lot of other people need help with this... how do you fix the proximity sensor issue on the Nexus 4?
    I found some code you can punch into the Root that fixed it for the Samsung Galaxy Note II... maybe there's something similar.
    Code:
    $ su
    $ echo 0 > /sys/class/sensors/proximity_sensor/prox_cal
    $ echo 1 > /sys/class/sensors/proximity_sensor/prox_cal
    Cheers!
  2. #2
    Gregg Moran's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How do I fix the Proximity Sensor issue?
    how do you apply the code to the root of a note 2 to make the blank in call screen to work?
  1. Is there a way to get my alarm time on the lock screen?
    By woahohkelsey in forum Samsung Galaxy S5
    Last Post: 07-27-2015, 03:08 AM
  2. rooting after the newest ota update?
    By tooandrew in forum Verizon Galaxy Note 2
    Last Post: 05-12-2014, 11:32 PM
  3. Replies: 2
    Last Post: 05-12-2014, 12:46 PM
  4. Sony Xperia Z ultra or the Google play edition
    By valapsp in forum General News & Discussion
    Last Post: 05-12-2014, 10:48 AM
  5. rooting after the newest ota update?
    By tooandrew in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 05-12-2014, 03:35 AM
