Results 1 to 5 of 5
    Default Wireless Charging and Cases
    How does the case affect the speed of wireless charging. Really a physics question relating to the distance between the two coils.
    Does anybody have real world experience out there of different charging rates with case on and case off. It also prompts the question as to why I can't seem to see a bumper case for the Nexus 5 that's like the one for the Nexus 4 (ie no back or front, just sides and top).
    Thanks in advance.
    Jon
  2. #2
    Default Re: Wireless Charging and Cases
    If your case is metal or separates the phone more than 4cm, the wireless charging will not work (magnetic induction will not work).
    Does your Nexus 5 charge fine without the case?
  3. #3
    From what I remember in collage, a long time ago, lol.
    The basics of wireless charging is that of a simple transformer. Two coils of different size, one is powered by the AC in the wall outlet which energizes the first coil creating a magnetic field which rises and collapses based on the Hz frequency of the power supplied, 60 times a second here in the USA for example.
    The other coil is located in the back of the phone and is connected to the battery in the phone.
    As the magnetic field rises and falls in polarity it induces an electrical current in the second coil in the back of the phone.
    The ability of the second coil to convert and capture the induced current and ultimately charge the phones battery is a measure of its power factor. The power factor is at its greatest or best when both coils are as close as possible and, under ideal conditions, can be close to the same power factor found in a standard wired wall charger. As the two coils move apart or out of alignment the power factor decreases and the charging potential is lessened up to the point that the phone will not charge. So really there are three things to keep in mind if one wants the best wireless charging using induction, 1) keep the two coils in as close contact as possible, 2) keep the two coils parallel to each other and in alignment to each other 3) make sure the material located between the two coils " aka the charging mat and the phones battery" is conducive to magnetic flow "ie, not metallic".
    If the above was TLDR, then the simple answer is, any phone case will lessen the wireless chargers potential, and depending on the cases material type and its thickness, some will effect more than others. As far as saying how much would have to do with how strong the first coil is and how saturated the second coil is. This is a particular of the charging mat and the phone that it is paired with. So there is no hard and fast rule. There is only ideal and degrees of lessening ideal situations, not a good or bad.
    jon_stewart likes this.
  4. #4
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    it has been reported that the Nexus 4 version of this case worked with the Nexus charging orb so there is a very good chance the Nexus 5 version will as well -
    Diztronic Matte Back Black TPU Case for LG Nexus 5
  5. #5
    Wife and I both have Nexus 4's (but I have an N5 arriving tonight!) in this case Amazon.com: i-Blason Slim Fit S Line Flexible TPU Case for Google Nexus 4 Smart Phone E960 LG 8gb 16gb (Black): Cell Phones & Accessories and we use this charger Energizer Qi Enabled 3 Position Inductive Charger Black | eBay
    The combination works great with no issues at all. Charging is very fast; the N4's normally spend the entire night on the charger however they are usually fully charged within an hour or two of placing them.
  1. Androuid 4.3 and FOXFI
    By rcolman in forum Samsung Galaxy Note 2
    Last Post: 01-11-2014, 12:42 PM
  2. Question regarding AT&T and Straight talk.
    By Joe the Insider in forum Google Nexus 5
    Last Post: 11-13-2013, 05:32 PM
  3. Contacts database editing and new field ordering.
    By Chuckcell in forum AT&T Samsung Galaxy Note 3
    Last Post: 11-06-2013, 10:47 PM
  4. Charging Issues
    By jwatson77 in forum HTC One M7
    Last Post: 11-05-2013, 08:12 AM
  5. note 3 case
    By Rohit Ramesh1 in forum Samsung Galaxy Note 3
    Last Post: 11-03-2013, 09:22 PM
