Re: nexus 5 bumper case problem
wish i read up on this thread before i bought the bumper case... we'll see how it goes. i got the gray one so i'll be on the lookout for the aforementioned issues. i did get it recently when the play store was selling accessories for 25% off so it that may ease any durability/quality issues i may see...
UPDATE: i received the case on saturday and have some observations:
- the case IS flimsier at the bottom edge as another poster pointed out.
- the case's edges are quite rigid and are raised a mm or two and provide modest protection; you can place it face down and the screen will not touch any flat surface. the same is true for the camera lens; there seems to be a mm of protection so the lens would not touch any flat surface area if the phone is placed on its back.
- the gray color case i got is not gray but more of dark off-white.
- the sides of the case all around is canted; this seems to aid in grip
- the inside of the case has about a mm raised border all the way around. that combined with the canted sides seems to provide a "buffer" of space for the phone in case of drops. this seems to be a smart, albeit, plain and simple design to protect against drops.
- the case looks cheap. its worth $10. max.
in hindsight, i should've gotten the speck case for the same amount of money. i'm not thrilled with their color selection but they have well made, well protecting cases. i think i'll be ordering a speck case soon...
