Results 1 to 3 of 3
    Default Replacement battery
    I must not be the only one who thinks the battery on the Nexus 5 is pretty rubbish.
    I was wondering if there's any websites I can buy a higher mAh battery from to put in my phone. It runs out just after work and I'd like to use it for the day without 2 charges.
    Also does it require any soldering to replace the battery?
    P.S, UK sites would be appreciated, or those who ship to the UK
  2. #2
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    Default Re: Replacement battery
    Quote Originally Posted by Tvppy View Post
    Before you xchange your battery try few things :
    • calibrate battery
      check your apps for wakelock
      switch off LTE if poor or no coverage
  3. #3
    The battery is not replaceable and there is no room inside for a larger one.
    Pat
    Nook Color - CM10.1 ( Jelly Bean 4.2.2) on eMMC
    Google Galaxy Nexus - stock Jelly Bean 4.3
    Galaxy Nexus 10 - stock KitKat 4.4.2
    Galaxy Nexus 7 (2nd Generation) - stock KitKat 4.4.2
    Chromecast
    Nexus 5 - stock KitKat 4.4.2
  1. Battery Life: A Handy Guide To Having Some
    By KWKSLVR in forum Moto X
    Last Post: 12-31-2013, 12:40 PM
  2. Has my G2's battery gone bad?
    By batterywontcharge in forum LG G2
    Last Post: 12-29-2013, 01:12 AM
  3. Replacement charger
    By fofjjsr in forum HP Chromebook 11
    Last Post: 12-29-2013, 12:21 AM
  4. S2 Battery drain in only a few hours....why?
    By papeter in forum Samsung Galaxy S II
    Last Post: 12-28-2013, 09:01 AM
  5. Replacement charger for HP Chromebook 11
    By fofjjsr in forum Chromebooks
    Last Post: 12-28-2013, 07:38 AM
B
