Results 1 to 6 of 6
    Ben Stearman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default nexus 5 trouble downloading apps pls help
    so new phone, everything seemed like it was downloading fine and putting apps on there like this crappy dragon game and sky sports, then as i tried another app you can see it starts to download, it then gets up to around 90% or fully downloads it then it just goes off like i cancelled it or says installing which will last for ages. I will then get bored of waiting and go on an app or something and then when i look back at it, no message to say installing so i think great its done.... but nowhere to be found and needs downloading again. sorry for the bad language but its pissing me off big time. need advise pls help.
  2. #2
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: nexus 5 trouble downloading apps pls help
    try -
    1. Settings-->Accounts--->Google-->Remove Account--->Reboot
    2. Re-Add Google Account
    if all else fails - do a hard reset back to factory fresh state and manually resync/reinstall everything.
    good luck.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,086 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by Ben Stearman View Post
    Welcome to the forums!
    It may be one of two things. Something is up with the app in Play. Have you tried downloading it on a different device? Or, sometimes, I find apps download and install better on WiFi. No idea why, but sometimes it's better that way.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    well its my wifi at home worked the first 2 times then i tried downloading a game but couldnt find the right one so deleted two versions of it, then found the right one and thats when it started happening.
  5. #5
    patruns's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Could you maybe explain that a little more? Deleted how? What is the name of the app?
  6. #6
    Mark Doyle1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just a bought a new Nexus 5 and have downloaded a bunch of apps. However, suddenly it won't download any more apps. I just get a thin blue line going across the screen that looks like its downloading but it never completes and it doesn't show me how far along it is. I have tried shutting down etc. Any suggestions? Thanks much!
  1. HELP!
    By angela horner in forum AT&T HTC One
    Last Post: 01-25-2014, 12:02 PM
  2. Huge Problem, app not installing and others
    By SirDarknight in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-21-2014, 10:32 PM
  3. Good app for PowerPoint presentations
    By xuqe in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-21-2014, 01:03 PM
  4. Messaging App Always Scrolls to Top after entering new message.
    By alphacoleman@gmail.com in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-21-2014, 08:56 AM
