1. whitenoise013's Avatar
    Hi guys,
    Well I lost my nexus 5 micro USB cable but I still have the wall adaptor. I've read a lot of articles that state that using a 3rd party cable/charger can do bad for the phone.
    Does it make a difference to use to a 3rd party cable (I have a Samsung USB cable) with my nexus charger? Or is there any way I can get a nexus USB cable? I couldn't find them in amazon.
    Also does the charging speed has anything to do with the USB cable? (USB 3.0 , USB 2.0 difference perhaps? ) I don't know if its just what I felt but I think the phone charged a bit slower with my Samsung USB cable.
    04-13-2014 11:05 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Any microUSB cable should be fine for charging. They can't really cause damage.
    04-13-2014 11:50 PM
  3. Golfdriver97's Avatar
    Welcome to the forums.
    I found this: https://play.google.com/store/device...ging_accessory
    Other options can be found here: LG Nexus 5 USB Cables - ShopAndroid
    04-13-2014 11:55 PM
  4. Ed Briggs's Avatar
    Unless you're buying a cut-rate chinese cable, any micro usb cable should work fine. But even most cheap ones should work ok.
    04-15-2014 01:32 PM
  5. whitenoise013's Avatar
    Thanks for your replies guys! Such a good feeling to be part of this community. Thank you once again!
    B. Diddy likes this.
    04-19-2014 12:23 AM
  6. Andy_Bell's Avatar
    tock
    Hi guys,
    Hi - I bought a spare cheapo micro usb cable from Amazon and it was MUCH MUCH slower thean the cable I got with the 'phone. Literally hours to recharge from "flat" compared to a couple of hours with stock cable
    04-20-2014 03:35 AM
  1. Waiting for the Yellow Nexus 5!
    By Harry Wild in forum Google Nexus 5
    Last Post: 05-07-2014, 02:07 PM
  2. My new Nexus 7 won't download any apps!
    By StickyLabel7 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-14-2014, 10:34 AM
  3. USB to Ethernet adapter and USB to go questions.
    By Ion_NotePro in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-13-2014, 05:35 PM
  4. Security for nexus 10 is it needed
    By joetheghost in forum Nexus 10 Rooting, ROMs, & Hacks
    Last Post: 04-13-2014, 05:28 AM
  5. Delete post
    By Greg C in forum Nexus 4 Accessories
    Last Post: 04-13-2014, 12:04 AM
