1. ianhanson85's Avatar
    So like most I have grown quite frustrated with the battery life of my nexus 5. Has anyone used a battery case? If so, which brand and how well did it work? Also, how much do they cost?
    I see a generic one on eBay for 20 bucks that looks alright.
    I'm just wondering what others have used.
    Thanks
    05-23-2014 12:16 AM
  2. Jonathon Pollard's Avatar
    I have had this same issue with my Nexus 5 and I did an extensive search on Amazon and found the i-Blason rechargeable case, looked at reviews on the product and found they were all positive so I decided to try it out I've have the case for about two weeks now and I it works amazing and did a charge test with it with my battery at 20% and within two hours my battery was at 65-70% charged but I have found if you charge it and continue to use your Nexus 5 heavily then it will not charge as fast but overall well worth the money I purchased the case for 65$ but there are others out there much cheaper that I haven't tried yet so good luck to you
    06-07-2014 11:36 PM
  1. kitkat battery drain?
    By robocp4 in forum Droid RAZR HD
    Last Post: 01-12-2015, 12:57 PM
  2. Google Services draining up all of battery?!?!?!
    By Redx in forum Verizon Galaxy S III
    Last Post: 05-27-2014, 12:26 AM
  3. THIS is Why I'll Only Buy a Phone With a Removable Battery
    By Murph5150 in forum Verizon Samsung Galaxy S4
    Last Post: 05-24-2014, 07:33 PM
  4. Screen Casting was live on my Nexus 7
    By TKDnerd05 in forum Google Chromecast
    Last Post: 05-24-2014, 03:48 PM
  5. Nexus 4 LED light
    By grakhra in forum Google Nexus 4
    Last Post: 05-24-2014, 06:18 AM
