Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By EvilOverlord
    Default TiBu File Will NOT Copy to PC from Nexus 5
    I've been searching high and low for a solution to this ridiculously simple problem, but none of them work. I just installed Titanium Backup on my rooted N5 and ran my initial backup. After completion, I connect to my PC via USB and browse to where the 'TitaniumBackup' file is located on the N5 (/storage/emulated/legacy/TitaniumBackup - file is 4kb in size). I cannot copy this file over to my Win7 PC no matter how I try to do it. USB debugging is enabled and I have rebooted the phone several times with no luck.
    What stupid thing am I missing here? Will I also need to copy the 'TitamiumBackup' folder over as well since the file noted above is only 4kb?
  2. #2
    Default Re: TiBu File Will NOT Copy to PC from Nexus 5
    It may be protected. If you are using Pro you can back up/sync to your Dropbox or Google Drive account.
    Alternative: Try force closing the app and then making a copy.
    Pat
    Nook Color - CM10.1 ( Jelly Bean 4.2.2) on eMMC
    Google Galaxy Nexus - stock Jelly Bean 4.3
    Galaxy Nexus 10 - stock KitKat 4.4.2
    Galaxy Nexus 7 (2nd Generation) - stock KitKat 4.4.2
    Chromecast
    Nexus 5 - stock KitKat 4.4.2
  3. #3
    What I do is, download the TiBu folder from the N5 to PC over WiFi, using AirDroid. No hassles of connecting cables. Works perfect for me.
    AirDroid -
    srkmagnus likes this.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    6,746 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Quote Originally Posted by EvilOverlord View Post
    AirDroid -
    Wireless methods to transfer files are great!
  1. Google Nexus 4 - No Notifications Over Data
    By toka1300 in forum Google Nexus 4
    Last Post: 12-27-2013, 10:07 AM
  2. Any Way To Get Stock Android On Galaxy S4?
    By Gabe Raffinan in forum Samsung Galaxy S4
    Last Post: 12-25-2013, 07:12 PM
  3. Qi-compatible Case for Nexus 7 (2013)
    By yakkwak in forum Google Nexus 7 (2013) Accessories
    Last Post: 12-25-2013, 06:54 PM
  4. Flash from cricket to sprint
    By Trillyx in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-24-2013, 01:58 PM
B
