Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By joaofernandes
    jmiesse134's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 5: Color Profiles in Franco Kernel Updater
    I updated to most recent version There are several pre adjusted color profiles to choose from. some are terrible and some are fantastic.
    No more "washed out" look.
    I have been going through some of these . I currently use ADITYA_AMOLEDARKS. It is quite saturated though.
    Post what is working for you.
  2. #2
    krifor03's Avatar
    Posts
    Global Posts
    163 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Color Profiles in Franco Kernel Updater
    Faux123, if you want a truer representation of colors. you should download Display tester so you can see where your gamma is resting after you make display changes
  3. #3
    ThatGuyLurkin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Using same profile. AmoledDarks. It's pretty, but yeah. Saturated a lot.
    PerfectRGB is also nice. I just miss the saturated amoled look. So I end up going back. :/
    Sent from my Nexus 5 using Tapatalk
  4. #4
    joaofernandes's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm using the aditya_TRUERGB and it's soooo nice. When u compare side by side with an stock nexus 5 the difference is ridiculous.
    EDIT: I swith to the piereligio_truergb_v5, is better than the Aditya, but not much
    krifor03 likes this.
  5. #5
    kellyrx8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Piereligio_True_RGB_V3.1 is what im using....
  6. #6
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I switched to tjkv and it's pretty cool, has a lot more contrast than piereligio_truergb_v6. I really recommend this one for u guys. You can get this profile and other awesome profiles on this link https://www.dropbox.com/sh/izp5dwyxl73xlt2/wehHWcJdQE. I also recommend use the Galaxy S5 wallpaper so you can see how freaking cool is this display!
  7. #7
    pdangcil's Avatar
    Posts
    Global Posts
    151 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 5: Color Profiles in Franco Kernel Updater
    Vomer Amoled. Try it!!!
  8. #8
    Reppy07's Avatar
    Posts
    Global Posts
    27 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I like vomer amoled myself as well. Very nice.
  9. #9
    Reppy07's Avatar
    Posts
    Global Posts
    27 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I also like perfect 2.2 as vomer amoled will sometimes seem a little too dark
  1. Wifi Not Turning On in Note 3
    By Akshay T in forum Samsung Galaxy Note 3
    Last Post: 04-22-2014, 02:24 PM
  2. Replies: 5
    Last Post: 02-05-2014, 06:52 PM
  3. Kit kat update for HTC one in Africa
    By Barryotus in forum HTC One M7
    Last Post: 02-05-2014, 06:04 AM
  4. Can I update firmware if Knox Warranty is voided?
    By zartre in forum Samsung SAFE and KNOX
    Last Post: 02-01-2014, 09:35 AM
