Nexus 5: Paranoid Android and Franco kernel?
Nuuq
357
Does franco kernel work with paranoid android now?
Live long and prosper.
Nuuq
357
Re: PA and franco kernel?
I hope this question will be answered as I want to learn more about this Kernel thing. Thanks.
Before someone who knows the thing answers, I can tell you that I have flashed franco kernel, and it seems working. Color management works great... But I'm just a brave noob :) ti might want to wait for expert to answer this...
Do you have any LCD bleedish light on black background?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Yes, you can use Franco kernel with Paranoid Android (PA) and any other ROM built from AOSP sources. The kernel is not compatible with CM or ROMs built from CM sources.
I have not gone in and changed the color settings. Though, have played around with different per-app configurations to see what works the best and extends battery life for me. Something to consider if you haven't already don't that.
Nuuq
357
Got FK on my PA N5 and this is what I got...
Sent from my Nexus 5 using Tapatalk
itamargs
