Phone -> Clear Frequents
Shocktribe
69
Is there any way such as an app or xposed module that can turn off my frequent callers. I find it annoying and only like to keep my favorites. Can some one please help me?
jj14x
995
24
Not sure if there is an app/xposed module that does that, but you could switch to a different dialer app from the play store that doesn't show frequents.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
I don't think there is a module either. You can create folder on the home screen with all your favorite contacts for quick dialing. Probably not exactly what you are looking for, but it'll do until there is a better solution.
asha_kanta_sharma
