1. chrispher86's Avatar
    I'm running Beanstalk rom 3-25-2014. I was on the previous version prior to that and dealing with random reboots all day. After a full reset and an updated rom version, I am no longer experiencing random reboots. However, after my battery drains down past 50%, if I reboot my phone then it shows 22% or sometimes less. Just wondering what's going on.
    03-26-2014 01:40 PM
  2. Golfdriver97's Avatar
    Did you do a clean install on the update?
    03-26-2014 10:54 PM
  3. UJ95x's Avatar
    Also try fully draining your battery to calibrate it. 100->0 and back to 100
    Sent from my Galaxy S4 running SlimKat 4.4.2
    03-27-2014 12:32 AM
  4. jj14x's Avatar
    Please don't fully drain your battery (down below 5%) - it is among the worst (normal) things to do to your battery. Well, tossing your battery into a fire would be worse, hence the "normal" qualifier.
    03-27-2014 10:41 AM
  5. chrispher86's Avatar
    Thanks guys. I did do a clean wipe. I haven't had to "drain" the battery down to 0 because its doing a pretty good job by itself. The only thing I can think of is that I have double tap to wake and double tap to sleep (on the notification bar) activated as well as active display. I know that stuff drains the battery more but I don't see how that justifies losing 30-40% on a reboot though. I've ordered a Mugen 3000 mAh battery case so maybe that'll help me get through the day.
    03-27-2014 12:51 PM
  1. Galaxy S3: battery needs replacing
    By ebw1969 in forum Samsung Galaxy S3 Mini
    Last Post: 03-27-2014, 12:28 PM
  2. which app use more battery
    By mfaridi in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-27-2014, 12:00 PM
  3. Note 3: Is my overnight battery drain normal?
    By jaystaygrindin in forum Samsung Galaxy Note 3
    Last Post: 03-26-2014, 05:18 PM
  4. s3 mini battery draining problem
    By Shiv Rulz in forum General Help and How To
    Last Post: 03-26-2014, 01:04 PM
