Results 1 to 4 of 4
    HarikaPambi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Touch not working on Right side of the Screen on Nexus5 -32GB.
    Hi, I'm facing issue while accessing Nexus 5 (32 GB) .
    Touch is not working on complete right part of the screen. Any one faced such kind of issue till now.
    Observing a line on top and bottom of the screen.
    I did factory reset as well, but after few hours again I observed the same issue.
    Any suggestions?
  2. #2
    Sophia Zhao's Avatar
    Posts
    Global Posts
    99 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Touch not working on Right side of the Screen on Nexus5 -32GB.
    It most likely the screen connector get loose. So you can check it first.
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Sounds like a broken digitizer that need to be replaced. Have you contacted Google for a replacement?
  4. #4
    Subash VS's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Re: Touch not working on Right side of the Screen on Nexus5 -32GB.
    Im Facing the exact same issue now, What steps you have taken for the issue, do you replaced the screen Digitizer or fixed on your own ?
  1. Wifi issue at Work or public?
    By Surend ran in forum Samsung Galaxy S5
    Last Post: 05-19-2014, 03:47 PM
  2. Replies: 2
    Last Post: 05-09-2014, 05:02 PM
  3. Rooting and loading CM11 for the first time
    By mosesx in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 05-08-2014, 04:49 PM
  4. How much of an upgrade is the S5 from the S4?
    By rizzymo in forum Samsung Galaxy S5
    Last Post: 05-08-2014, 09:42 AM
