Results 1 to 4 of 4
    RaysBucsBolts's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Tried to flash L and now...problems. Please HELP!
    So I normally don't like these "help" posts as most of them are easily Google-able. But I've run every Google search imaginable and have been pouring through forums and cannot seem to pinpoint my problem and where I went wrong.
    I tried to flash L using the NRT 1.8.4 and everything seemed to be working fine but then I got stuck in a bootloop. I then went into Recovery Mode and wiped the cache, however, it was still stuck in bootloop upon reboot. I decided to bite the bullet and just try to flash back to 4.4.4 using NRT's Flash Stock and Unroot: Soft-bricked/Bootloop option.
    Everything went fine and the flash back to stock went fine. So I rerooted and it prompted me to flash a custom recovery using TWRP...something I've never done. Yes, I didn't have a backup. I am an *****.
    So I installed TWRP following all of the instructions and the root went perfectly. However, upon boot-up, I had at least 10 prompts saying one app or another is not currently working including all of my Google ones (all of my contacts appear to be gone and I cannot launch Gmail or really anything at all). I reinstalled my Xposed framework but most of that stuff is not working either as GravityBox is one of my error messages.
    I have pretty much zero functionality of my nav bar (recent tasks doesn't work nor does the back button) and my power button will not prompt a power option menu. When I swipe down my notification bar, my settings are all scrunched in in the middle of the screen and do not expand.
    I have no idea what I did or how to fix it and while I would hate to have to factory reset, it wouldn't be the end of the world.
    Has anyone ever encountered this or have any clue as to how I messed this up so badly?
    Thank you so much in advance!!!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,066 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Tried to flash L and now...problems. Please HELP!
    Quote Originally Posted by RaysBucsBolts View Post
    Welcome to the forums.
    First, can you link what file you used to try to flash L?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the welcome.
    I downloaded the Preview System Images from the Android L Developer Preview website (Setting Up the Preview SDK | Android Developers).
    Just read this warning on LifeHacker website: Warning: It's mentioned on Google's download pages, but it's worth repeating: flashing this will erase your device and all your data. Be sure to do a backup before you begin.
    So I may have screwed myself but I'm still hoping there are recovery options.
  4. #4
    Posts
    Global Posts
    33,066 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    No, there probably isn't. You should be able to get set back up on KK, by reflashing the stock images.
    Signed, a Nexus 5, AC forums app, and Android L.
  1. LG G3 T-Mobile to AT&T Compatibility
    Last Post: 02-19-2016, 07:48 PM
  2. Exchange tasks sync to what on kitkat
    By AlphaLolz in forum Ask a Question
    Last Post: 03-31-2015, 05:08 PM
  3. Tablet not allowing me to move apps to SD card
    By yesnik09 in forum Samsung Galaxy Tab 3
    Last Post: 07-11-2014, 05:57 PM
  4. Impossible to connect my Mac to the new Samsung Tab S
    Last Post: 07-09-2014, 05:56 PM
  5. google play store problem
    Last Post: 07-08-2014, 01:23 PM
