1. Sergiusz Jasper's Avatar
    Bootloader is open had/have TWRP recovery.
    So issue is I downloaded and flashed wrong stock recovery by mistake looks like the one for Nexus 5 not 5x did not notice that X was not present.
    Now the phone boots up normally but will not go into recovery at all, did try using app since it's rooted but no luck.
    So I'm stuck with a working phone but no way of going into system recovery.
    Can't factory reset either.
    Any help would be great Ty.
    Basically was trying to unroot in order to run N android.
    I am able to go into fastboot but nothing after.
    07-03-2016 09:02 PM
  2. Sergiusz Jasper's Avatar
    solved ...uploaded an older version of TWRP recovery and it worked .
    07-03-2016 09:29 PM
  3. Golfdriver97's Avatar
    Did you flash the recovery through the bootloader?
    07-08-2016 09:19 AM
  4. Sergiusz Jasper's Avatar
    I used an app for TWRP form play store to upload the older version after that update to the new.
    07-08-2016 04:20 PM
  5. Sergiusz Jasper's Avatar
    Actually used this
    07-08-2016 04:22 PM
  6. Sergiusz Jasper's Avatar
    This app let me flash the version I needed
    07-08-2016 04:23 PM
  7. Golfdriver97's Avatar
    I've heard some good stuff about them. Never used that app though.
    07-08-2016 04:25 PM
  1. 'Funny' problem-lock screen waking up with every notification
    By muki991 in forum Samsung Galaxy Note 4
    Last Post: 07-05-2016, 02:37 PM
  2. Will the Android N fix the sync issues with Fitbit?
    Last Post: 07-05-2016, 05:12 AM
  3. Replies: 1
    Last Post: 07-05-2016, 04:56 AM
  4. I buy an verizon S6 edge phone, can i use it with cricket?
    Last Post: 07-03-2016, 08:43 PM
  5. please help me stop being hacked
    Last Post: 07-03-2016, 08:34 PM
