1. CreatedAcForOneQuestion's Avatar
    After rooting, Playstore didn't worked properly and in one turorial stood that changing Ip adress may helps. So i went to advanced settings, changed DHCP to static and then, what probaly sounds stupid, i also changed my IP adress to the same as the one shown in the tutorial picture. Since then i get authenfications problems the whole time.
    I've switched back to DHCP, restarted my phone and router and even formated my phone because i thought it would fix this. Apparently i still have authenfications problems
    How you see i'm a noob at this and haven't really found a solution through googling. How can i fix this? Thanks for all answers
    (I have Google Nexus 5x)
    08-02-2016 04:12 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved to the N5X Rooting forum.
    Have you already tried rebooting your router? Are you unable to connect to any wi-fi network, or is it only your home network?
    08-03-2016 11:52 AM
  1. Replies: 3
    Last Post: 08-28-2016, 08:00 AM
  2. WiFi will not turn on, no networks listed.
    By dlmurphy in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 08-08-2016, 06:31 PM
  3. wlan / wifi not switching on
    By naimshaikh in forum Ask a Question
    Last Post: 08-05-2016, 09:21 PM
  4. Galaxy tab s2 - dragon quest iv problem
    Last Post: 08-02-2016, 02:53 PM
  5. Replies: 2
    Last Post: 08-02-2016, 12:14 PM
