Nexus 6P Bending and Breaking Thread
Status
Not open for further replies.
Re: Anyone have the "bulge" on the back/bottom piece?
No issue with mine
My "early" model is fine. Only bulge is dat camera hump :P
LOL thanks Jerry and everyone so far! Yea, just makes me nervous, but worse case I can slap a case on and, poof it's gone :)
Or just request another one.
Nothing on mine either. I'd definitely ask for a new one. Hopefully it doesn't take a while.
Mine doesn't have a hump down there, but it is a little unevenly seated. So one side is flush and the other is slightly recessed. Doesn't bother me one bit.
No bump on mine. Maybe try applying a little heat, or just get a new one.
6P bend and scratch test, not good viewing!
I just watched this video as I am still waiting to order the 6P but I am not so sure now, sorry if this video upsets some owners but I feel it needs to be seen just so owners are aware that it seems quite a fragile phone.
Re: 6P bend and scratch test, not good viewing!
Interesting. If you watch his other videos he does not seem to hold the lighter on nearly as long, it looks like for the 6P he needed longer just for it to show some sign, and by that point it was permanent. Curious if he tried that with the others.
Anyway, as I will rock a basic case and tempered glass protector, only the bending test would really worry me. And even so, unless you take a pretty terrible fall, it seems like you would not often have to worry about it bending like that.
I'm still looking forward to my 6P.
I doubt its as bad as the video looks. He compromised the integrity of the phone by cracking the glass and heating it up with fire. That is not considered normal usage, lol.
I have a theory that this is just a little publicity stunt to get the early adopters to subscribe to his channel.
I hope you're right as I was just about to order the 6P but this has thrown me a bit!
All phones will suffer from that abuse. Nothing to worry about. Who in their right mind would spend hundreds of pounds an then purposely scratch it or hold a lighter to it or try and bend it like that.
If this is a true representation of the phone's durability I am going to have to go back to the MXPE.
Status
kctraci1
