After using this 6p, I've noticed in the battery usage screen, seeing apps that I have no idea what they are. The icon for them looks just like the Android robot that you see next to Android OS, but instead of being gray, they are black, and the only name on them is 99070, 99068, 99077, etc. There is no information on them other than what I've detailed above, and when you tap on them, then next screen only says how long they've been active and how much battery they've consumed. There is no button to view them in the apps section of the settings either. Normally I'll see one entry when I go into the battery usage section, but right now I'm seeing 4 entries. Is anyone else seeing this in their battery usage screen? Have any idea what it is or if it's bad or not?
Also, I got my 6p through the Google Store and it is stock, unrooted, and bootloader intact. I haven't even sideloaded any apps on it. I've just never seen this on any Android phone I've owned before and would like to make sure it isn't something malicious.
I'm also wondering if it's causing my abnormal battery usage as well. Overnight I slept about 5 hours and lost 7%. I charged the battery to full this morning and after 1 hour of screen on time browsing the web with Chrome and brightness set to about 50%, my battery level is at 75%.
So please, any help is appreciated.
