I just bought a leather folio case that has a sleep mode function. I am finding the lag too long when I open the cover to use the phone. Without the case there is no discernible lag from off or sleep mode to on.
Is there an option to disable the sleep mode function?
I have set the sleep time to 30min and turned off Daydream. I have enabled developer options but don't see anything to shut down sleep mode function.
Thanks
Thanks
