05-25-2017 09:38 PM
184 ... 678
tools
  1. GSDer's Avatar
    What is Lookout? I don't have that in my accessibility menu.
    It's a 3rd party application Lookout Security & Antivirus https://play.google.com/store/apps/d...id=com.lookout
    03-27-2017 11:42 AM
  2. The19thD0CT0R's Avatar
    Ah I see. I'm using CM Cleaner to achieve the same effect.
    03-27-2017 01:42 PM
  3. Mukulthegamer's Avatar
    A 51 sec video just cleared my confusion ... Try it its working
    joe1blue likes this.
    04-08-2017 01:49 PM
  4. joe1blue's Avatar
    For some strange reason on my Samsung Galaxy S7 Edge I don't even have that option inside the settings it's really frustrating the hell out of me. Thanks for the video post though.
    05-04-2017 03:49 AM
  5. Dreamspinner3's Avatar
    Android 7.0
    Google 7.1.29.21.arm64
    Phone Samsung Note 5
    Carrier T-Mobile
    "Ok Google' notification tone stopped working and nothing I've tried has gotten it working again. Been doing this since updated to Nougat. Please offer fix to get it working again. Thank you.
    05-12-2017 01:11 PM
  6. Ausbrjl's Avatar
    Android 7.0
    Carrier T-Mobile
    05-15-2017 06:29 AM
  7. Ausbrjl's Avatar
    I don't know if anyone has already suggested this as a fix for not having volume from Google assistant, but try saying turn it up when it asks how it can help
    05-15-2017 06:30 AM
  8. Mdoc7's Avatar
    I just fixed this on my Samsung Galaxy Core Prime.
    1.Drag Google app to App Info to get into Google app info
    2.Clear the app data (not the cache!)
    3. (This will cause Google app to lose the microphone response to "ok google")
    4.Start Google app manually (click on it--not the search bar)
    5.go through the short setup that results after manual start
    6.beep sound response after "ok google" should work.
    05-25-2017 09:28 PM
  9. Mdoc7's Avatar
    I suspect Google data got corrupted.
    05-25-2017 09:38 PM
184 ... 678
  1. Transfer Google Play Apps From Phone to Tablet
    By GalaxyGirl23 in forum Samsung Galaxy Tab S2
    Last Post: 04-03-2016, 04:06 AM
  2. how do i stop pop ups on my phone
    Last Post: 04-02-2016, 01:17 PM
  3. Replies: 0
    Last Post: 04-02-2016, 12:06 PM
  4. Why cant I send text messages to specific people?
    Last Post: 04-02-2016, 11:28 AM
  5. Making call via bluetooth headphones unlocking device(S7 Edge)
    By Jcicalese in forum General Help and How To
