Last night I left my phone off the charger and my phone went into deep doze and lost 34 percent in like 4 hours. Wtf is going on? My battery life has been crappy since N. Is anyone having similar issues?
I lost 5% overnight with battery saver and data saver (though was on WiFi) enabled. I would lose 2-3% overnight on MM without doing anything (with battery saver off). Overall, the battery life is worse on N, and it's a bit sad. I wish Google would step up their game, because this is a widely published issue (see the plenty of threads here, and posts on reddit).
If you show us a screenshot of what apps are using how much of the power, we might be able to help you better. One power-hungry app can kill the battery in a couple of hours. (I've stopped using my VoIP app for that reason.)
What leads you to believe that your device was in doze? I see nothing in that screenshot that says anything about what sleep state (if any) the device was in.Check out what happens while in doze.
I'm hoping enough people will make it noted and Google will act (Google please?!)In actuality, it really pisses me off because Google bragged all about N going even deeper into battery saving features and here we are with dramatically worse battery life. I'm just pissed off about that. ??????
I can neither agree nor disagree with your statement about battery life on Nougat being worse than on Marshmallow since I never bothered to track specifics on Marshmallow. I suppose I could un-enroll from the Beta program and flash the last 6.0.1 build to see what happens, but that's really a lot of effort. Perhaps someone still on Marshmallow could do that before upgrading?I lost 5% overnight with battery saver and data saver (though was on WiFi) enabled. I would lose 2-3% overnight on MM without doing anything (with battery saver off). Overall, the battery life is worse on N
I'm doing okay with mine
My Huawei Nexus 6P battery averages 1d 8h 32m (14h 32m 0s active usage) on a single charge. Check out GSam Battery Monitor: - https://forums.androidcentral.com/e...ps/details?id=com.gsamlabs.bbm&token=INT-TWy1 #badassbattery
Since the latest update to my phone my battery life has been sucky I don't own a nexus but an LG stylo 2 I have used it heavily for 8 months and now my battery dies from like 15-2 percent. I bought a non oem backup battery worked fine until the last big update they did then my backup said unauthorized battery in device and shut down. So now I finally broke down and spent $10 on eBay for a supposed new oem battery I hope it lasts longer than this current battery or I will be pi**ed
