Verizon Visual Voicemail with 7.1 on the 6P
jam4775
406
6
After updating to 7.1 on my 6P I noticed new voicemail notifications popping up... when I click on it it brought me to the phone dialer's voicemail tab and I prompted with with Verizon terms and conditions to accept.
Verizon is now supporting the stock dialer's built in voicemail!!
Raydee
49
So after buying my 6p I had to call Verizon and have the basic vvm turned off and use google voice instead. With the new beta can I call Verizon and have the basic vvm turned back on or do you have to use the premium vvm service that they offer?
bpe4
311
Don't have to call. Log into your account via the web. Look at your features for your phone. You should see an option to turn on Basic Visual Voicemail. It's free.
Raydee
49
So would I then get rid of Google voice? I am only using it for voice-mail right now since Verizons visual voice-mail did not work on the 6p when I first purchased it.
anotherlab
6
To disable Google Voicemail on your phone, just dial *73 and press the cal button. Your phone will make a quick call and hang up. That unlink Google Voice from your phone. I just tried it and worked just fine. Then I switched it back to Google Voice.
mustang02
201
What the what? I have been using Google Voice on my 6p since launch. Why does it not work for you?
Your gv voicemail works on the dialer? You'd be the first. I'm not talking about google voice working.
fancyfranci
