Results 1 to 3 of 3
    dsuppa's Avatar
    Posts
    Global Posts
    160 Global Posts
    Default CM10 Nightly Build Changelog
    Is there a changelog or anything for the CM10 Nightlies so you can see if anything was added before you waste your time flashing from a previous nightly?
    I clearly love the Nexus line......
    Devices: Nexus 7 16, Nexus 7 32, Galaxy Nexus, Kindle Fire running CM9
  2. #2
    bespinct's Avatar
    Posts
    Global Posts
    444 Global Posts
    ROM
    Stock!
    Default Re: CM10 Nightly Build Changelog
    Sure. You can look and choose the date of the build.
    Thanked by 2:
    dsuppa's Avatar
    Posts
    Global Posts
    160 Global Posts
    Default
    Thanks
    Sent from my DROID RAZR using Tapatalk 2
